search down- code 41- primary oxygen sensor heater?
Old Jul 31, 2007 | 10:12 AM
kcrxxx's Avatar
Default search down- code 41- primary oxygen sensor heater?
I'm throwing a code 41- turns out to be the primary oxygen sensor heater. Anyways im in the process of trying a new oxygen sensor, but was wondering what other ppl have done to solve this code? Could this cause my engine to sputter at 5500 rpm? Or is that from having the cel light on?
Old Jul 31, 2007 | 05:03 PM
kcrxxx's Avatar
Default Re: search down- code 41- primary oxygen sensor heater? (kcrxxx)
bump for help
Old Jul 31, 2007 | 06:37 PM
IASI2010's Avatar
having the same problem but the secondary o2 sensor
Old Aug 1, 2007 | 09:17 AM
Relic1's Avatar
O2 heater means that the resistive heater element in the O2 is out of spec. 95% of the time replacing the O2 will solve the issue.
It could also be wiring, connector or ECU issues.
Old Aug 1, 2007 | 12:10 PM
kcrxxx's Avatar
I tried replacing the o2 with a functioning one, and still no luck. The car is sputtering when on the gas, could this be associated to the code? Also would the wiring problem have to come from the o2 wiring or just any wiring in general? I guess i'll just keep checking the wiring.
Old Aug 1, 2007 | 12:47 PM
Relic1's Avatar
the O2 heater is a very simple part. two wires, one black wire runs to ignition power, the other to the ECU.
sputtering over 5500 shouldn't be caseud by this code, but stranger things have been known to happen.
are you positive that there isn't two codes? easy to over look sometimes.
the sputtering, is it like it's running out of fuel, bogging or cutting out completely?
double check the ground wires on the thermostat and the engine-chassis ground wires.
.Hookedonhatch.
Dec 12, 2008 01:23 PM
vsm_EJ6
May 17, 2007 04:33 AM
efyou
Feb 7, 2006 06:16 PM
kapoosh valve
23
Jul 1, 2005 09:02 PM
VTC_CiViC
Apr 18, 2003 10:12 AM
