need help on TPS sensor removel
Old Jul 30, 2007 | 09:09 AM
Al-sonic's Avatar
Default need help on TPS sensor removel
im tryin to take my old TPS sensor but it seem like the screw has been welded on, is there anyone who know how to take it out?
Old Jul 30, 2007 | 10:24 AM
thinknology's Avatar
Default Re: need help on TPS sensor removel (Al-sonic)
should just be two screws that go through slots in the tps for adjustment... am i wrong?
Old Jul 30, 2007 | 10:26 AM
mmuller's Avatar
Mad Scientist
Default Re: need help on TPS sensor removel (thinknology)
have to grind a slot to be able to use a screw driver
Old Jul 30, 2007 | 10:27 AM
egsleepercivic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thinknology &raquo;</TD></TR><TR><TD CLASS="quote">should just be two screws that go through slots in the tps for adjustment... am i wrong?
if its jdm your right. but on USDM cars the tps is riveted on use a dremel make a slot for a flat head screw driver and twist them out
Old Jul 30, 2007 | 10:33 AM
Default Re: need help on TPS sensor removel (egsleepercivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egsleepercivic &raquo;</TD></TR><TR><TD CLASS="quote">
if its jdm your right. but on USDM cars the tps is riveted on use a dremel make a slot for a flat head screw driver and twist them out </TD></TR></TABLE>
ew.... sounds like fun i had to mess with my b16a tps mine were star bits
!WARNING!: before you take it off get a reading from it first if you can... i tried to set my tps before and talk about a mess i couldn't get i right (the number in the book didn't work)
CRX30436
Feb 6, 2008 07:00 PM
valentine97
Jan 14, 2008 12:44 PM
russianswty
Dec 23, 2006 09:20 AM
foam
Jan 8, 2006 07:03 PM
TDRacing
Jun 18, 2002 03:31 PM
