Can 2 bolts hold AC Bracket ?
Old Aug 1, 2007 | 05:19 PM
BoRiCuA's Avatar
Default Can 2 bolts hold AC Bracket ?
Can 2 bolts hold the ac bracket in place? including the 2 from the torque mount so that equals 4.......
Old Aug 1, 2007 | 09:13 PM
mgags7's Avatar
yes but why? better safe than sorry IMO.
Old Aug 2, 2007 | 03:17 AM
BoRiCuA's Avatar
Default Re: (mgags7)
well the 2 rigth side bolts of the ac bracket top&bottom the heads were snaped off, and after buying trying for a couple of days to extract the bolts with a reverse drill bit i only made it worse and didnt want to keep trying cuz the hole is getting wider and bigger. As we all know it's an aluminum block so I aint fukin with it.
I do have hasport mounts and the pass. side torque mount, but also wanted the driver side torqu mount. So you figure if i use the 2 left side bolts of the bracket and the 2 right side torque bolts that bolt up to the chassis i should be fine right?
Old Aug 2, 2007 | 12:49 PM
BoRiCuA's Avatar
Default Re: (BoRiCuA)
BUMP for more info needed please...
Old Aug 2, 2007 | 04:17 PM
BoRiCuA's Avatar
n1 help
Old Aug 3, 2007 | 02:22 PM
BoRiCuA's Avatar
do they sell a /c torque mount with only 2 bolts?
Old Aug 3, 2007 | 03:21 PM
h22crxpwr's Avatar
you are fine with the bolts you have in there.
acuteviet
Dec 9, 2006 07:22 AM
SyDuck
Dec 19, 2005 09:40 PM
Civichatch2k
10
Jun 26, 2003 06:57 PM
