stripped a bolt doing valve adjustment. now what????
Old Aug 3, 2007 | 07:16 PM
itr1244's Avatar
Default stripped a bolt doing valve adjustment. now what????
yup. i stripped one of the bolt .. while doing the valve adj.. the torque wrench never clicked.......
sooo what could i do ??
take the head off and bring it a machine shop??? is that only choice??
Old Aug 3, 2007 | 07:26 PM
02 accord's Avatar
Default Re: stripped a bolt doing valve adjustment. now what???? (itr1244)
Valve cover bolt? If the gasket doesn't leak, I wouldn't worry about it.
Old Aug 3, 2007 | 07:54 PM
itr1244's Avatar
Default Re: stripped a bolt doing valve adjustment. now what???? (02 accord)
no. one of these bolt . got stuck to the inner nut/bolt
and they spin together. and it's really hard to turn inner/outer bolts..
and the outer bolt won't lock
Old Aug 3, 2007 | 07:58 PM
02 accord's Avatar
The flathead is a bolt, and the "outer bolt" is a nut. Are you saying that the nut it stuck on the bolt and you can't turn the two separately? Then unscrew the bolt/nut and get a new one.
Old Aug 4, 2007 | 12:35 AM
mtber's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 02 accord &raquo;</TD></TR><TR><TD CLASS="quote">The flathead is a bolt, and the "outer bolt" is a nut. Are you saying that the nut it stuck on the bolt and you can't turn the two separately? Then unscrew the bolt/nut and get a new one.</TD></TR></TABLE>
+2
Old Aug 4, 2007 | 06:54 AM
itr1244's Avatar
Default Re: stripped a bolt doing valve adjustment. now what???? (mtber)
can i take both "flathead" and the nut right out?
or do i need to hold the flathead part and turn the nut to get it off?
Old Aug 4, 2007 | 06:57 AM
itr1244's Avatar
and what's the part number for those 2??? please?
http://www.sonsacuraparts.com/...Irno=
Old Aug 4, 2007 | 07:34 AM
itr1244's Avatar
anyone? someone?
Old Aug 4, 2007 | 07:48 AM
92_civic's Avatar
#9 and #19
Old Aug 4, 2007 | 08:07 AM
itr1244's Avatar
Default Re: stripped a bolt doing valve adjustment. now what???? (92_civic)
thank you
so i can just loosen these 2 and they will come out?
Modified by itr1244 at 12:23 PM 8/4/2007
Old Aug 4, 2007 | 08:23 AM
itr1244's Avatar
so once i take out the nut.. can i screw the flathead part and just screw that one off too?
Old Aug 4, 2007 | 09:52 AM
02 accord's Avatar
If the nut is stuck on the flathead, then just use a screwdriver to get the flathead out. The nut will come off with it (it's stuck to it).
Old Aug 4, 2007 | 12:17 PM
itr1244's Avatar
i managed to get the nut off the flathead screw..
i want to get the screw part off so turned it counter clock wise and when it gets to the point .. it stops turning..
Old Aug 5, 2007 | 11:19 PM
Mista Bone's Avatar
D Tranny Guru
you can't back it out thru the rocker, turn clockwise, but then you'll bottom out on the cam.........pull rocker assembly
Potential2nr
Jan 17, 2012 03:47 PM
spidermancivic
Aug 11, 2007 08:17 AM
chochocho
Jul 19, 2004 04:44 PM
88 rex
Jul 24, 2003 02:18 PM
