Piston to wall clearence
Old Aug 5, 2007 | 10:36 AM
5_Lug_B's Avatar
* B A N N E D *
Default Piston to wall clearence
Ok, im putting in P30 Pistons in my GSR block. Now the cylinder walls need to be rehoned and the pistons are stock bore. My current piston to wall clearence is .0035. Would I be good if I had it honed to .004?
Old Aug 5, 2007 | 10:38 AM
:Josh:'s Avatar
Default Re: Piston to wall clearence (5_Lug_B)
You would be better off just getting oversized pistons. .004 is pretty loose for a cast piston.
Old Aug 5, 2007 | 11:16 AM
5_Lug_B's Avatar
* B A N N E D *
Default Re: Piston to wall clearence (:Josh:)
ok, what is the reccomended clearence for a cast piston?
Old Aug 5, 2007 | 11:22 AM
4g hatch's Avatar
i dont think that honda recomends anything over .002
Old Aug 5, 2007 | 08:17 PM
slowcivic2k's Avatar
Default Re: (4g hatch)
.0004 to .0016" is the factory standard. I've had best results with a .001" clearance, and that is what I would recommend.
Old Aug 5, 2007 | 08:22 PM
5_Lug_B's Avatar
* B A N N E D *
Default Re: (slowcivic2k)
Hey thanks for the input on my question about the piston to wall clearence. Now would I be able to use my standard bore P30 pistons after I rehone the cylinder walls or would I have to go with the .0025 over?
Old Aug 5, 2007 | 09:26 PM
quicksilver1689's Avatar
i ♥ snails
dont mean to thread jack, but would you consider ideal for vitaras in a boosted application?
deanobob123
Apr 9, 2018 12:16 PM
DC4 Rasta
Jan 5, 2007 06:44 PM
95c1v1cs1
Jul 28, 2004 09:44 AM
ludelvr
Nov 26, 2003 03:56 PM
B20LS-T
May 13, 2003 04:17 PM
