Check Engine Light Code 54
Old Aug 2, 2007 | 02:16 AM
drive4aliving's Avatar
Modified by drive4aliving at 11:36 PM 8/14/2007
Old Aug 5, 2007 | 06:55 PM
cool_junk's Avatar
Default Re: Check Engine Light Code 54 (drive4aliving)
Unplug the computer and ohm between pin number 1(blue/red wire) and pin 11(white/red wire) on the 31 pin connector. You should have between 1600 & 3200 ohms if not check it at the pig tail at the sensor If you still don't, replace the sensor (Behind the timing cover)
Later, Drew
Old Aug 5, 2007 | 06:56 PM
cool_junk's Avatar
Default Re: Check Engine Light Code 54 (cool_junk)
The crank angle sensor is the one in the dizzy the crank fluctuation sensor is behind the timing cover.
form51
13
Mar 16, 2020 02:52 PM
pityocamptes
12
Dec 14, 2011 09:48 AM
7mile
Jul 1, 2010 02:10 PM
silverhonda123
Sep 6, 2007 07:53 AM
4gencivicef9
Aug 9, 2006 10:38 AM
