how does oil get to the head????
Old Aug 2, 2007 | 06:30 AM
RaceCarRyne's Avatar
Default how does oil get to the head????
how does oil get to the head when not in vtec?? i want to know if htere is a bypass in the vtec selinoid that allows oil into the head before vtec..
Modified by DC2jdmIntegra at 7:43 AM 8/2/2007
Old Aug 2, 2007 | 11:44 AM
Murk 'EM's Avatar
Default Re: how does oil get to the head???? (DC2jdmIntegra)
what do you mean?...there are oil passages going from the block to the head..the oil sump sucks up oil to the crank the crank then throws oil on the cylinder walls (thats how the walls get oiled) while the crank and oil pump are moving oil they move oil through the passages in the block up to the head which then get thrown around by the cams and the oil leaks back down through oil return passages
Old Aug 2, 2007 | 02:27 PM
Default Re: how does oil get to the head???? (95_acc0rd)
so if i block off the vtec selinoid with a solid plate the head will still get sufficent oil?
Old Aug 2, 2007 | 04:51 PM
BILLETGRIP's Avatar
if you dont want to use vtec why dont you just unplug it instead of goin thru the trouble of making a plate to block it off?
Old Aug 3, 2007 | 05:02 AM
Default Re: how does oil get to the head???? (BILLETGRIP)
the nice look of having a block off plate rather than that nasty selinoid..
Old Aug 3, 2007 | 03:16 PM
BILLETGRIP's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DC2jdmIntegra &raquo;</TD></TR><TR><TD CLASS="quote">the nice look of having a block off plate rather than that nasty selinoid.. </TD></TR></TABLE>
LOL. why dont you pull the engine out of it too? thats pretty nasty lookin to aint it?
Old Aug 5, 2007 | 05:47 AM
stumpyf4's Avatar
Head feeds oil to the VTEC solenoid, NOT VTEC solenoid feeding the head.
You will be fine making your block off plate. Toda block off plate is $150 MSRP!!!
Old Aug 5, 2007 | 10:21 AM
Default Re: how does oil get to the head???? (stumpyf4)
thanks
Dat1BVtecN
Mar 17, 2007 09:17 PM
RedRacerCivic
13
Jun 29, 2004 05:43 PM
tgreaves
Nov 7, 2003 07:42 AM
kasted1
Aug 20, 2002 09:16 AM
KS-R
Jan 17, 2002 01:44 AM
