temp gauge problem. please help
Old Aug 9, 2008 | 12:55 PM
lsvtecpower's Avatar
Default temp gauge problem. please help
have a 90 integra with a fully built ls vtec. and everytime i get on the highway to do a run my temp gauge goes to cold? throgh town or just driving its perfectly fine. i really dont know whats going on with this. i loose vtec and car runs lean as [freak] on the big end. but as soon as i let off the gas it usally goes up but sometimes it jumps around for a little bit then goes back to normal. can anyone please help me out. thanks in advance.
Old Aug 9, 2008 | 02:35 PM
slowcivic2k's Avatar
Default Re: temp gauge problem. please help (lsvtecpower)
Your thermostat is stuck open, replace it.
Why doesn't anyone replace the expendable parts on a rebuild?
Old Aug 9, 2008 | 03:03 PM
Default Re: temp gauge problem. please help (slowcivic2k)
its a brand new low temp one thanks. it only happens when i get on the freeway other than that its fine.
Old Aug 9, 2008 | 03:43 PM
Why would you put a low temp thermostat in your engine? Do you know that when parts heat and cool at rapid rates, they warp/crack? Put a 195F thermostat in there, and go home with more power, and better fuel economy. You WILL NOT get that with a low temp thermostat.
I would also like an explanation as to how you think running the engine colder will help you produce power. There is a reason engines run at 200F ALL THE TIME. How can you tune an engine that has a wide temperature variation.
LifeMage
Jan 19, 2008 10:51 PM
in10ceCiviC
Jul 19, 2007 12:10 AM
electric-boost
Dec 11, 2006 08:37 PM
Da1spaz247
Oct 12, 2005 02:33 PM
stRtypR25
Jan 27, 2003 07:51 PM
