Transmission Question For The Major Built Engines.
Old Aug 6, 2008 | 07:22 PM
Rotten Egg's Avatar
Default Transmission Question For The Major Built Engines.
im currently building my engine for about 500whp on a b18c1 engine, and i was wondering what the people with high hp were doing for trannys..will they hold stock (i know aftermarket clutch is needed) but im talking about the gearing and lsd itself.
thanks in advance
Old Aug 7, 2008 | 02:54 AM
1992Si's Avatar
With that low hp # a stock tranny will hold up fine. It's the torque # you need to worry about. Again, with the low # you'll be making you'll be fine.
You may want to look into better axles.
Check out the drag racing forum. The guy's with the 700+whp are still using OEM gear sets.
Old Aug 7, 2008 | 01:05 PM
Rotten Egg's Avatar
Default Re: (1992Si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1992Si &raquo;</TD></TR><TR><TD CLASS="quote">With that low hp # a stock tranny will hold up fine. It's the torque # you need to worry about. Again, with the low # you'll be making you'll be fine.
Check out the drag racing forum. The guy's with the 700+whp are still using OEM gear sets.</TD></TR></TABLE>
this is awesome to know...the tuner car i just came from was 75% maxed from the factory for power holding...thanks alot for the help
Old Aug 8, 2008 | 11:46 AM
Aquafina's Avatar
It is more about the entire setup than just the power number. 500whp is enough to shred teeth off of gears or the final drive.
Old Aug 8, 2008 | 02:53 PM
JBLAZE622's Avatar
i made 745 and i'm running a GSR tranny with a quaife and a handcuff
drtalon123
Transmission & Drivetrain
Nov 12, 2010 02:30 PM
christion
Honda S2000
22
Jan 26, 2008 09:34 PM
calvinPGMFI
Dec 14, 2005 06:47 AM
Nikos
Jan 31, 2005 08:32 AM
greekspeed
Jul 28, 2003 11:17 PM
