v-tech?
Old Aug 21, 2008 | 02:53 PM
BIGPAPAWACK's Avatar
Default v-tec?
ok stupid question being i am a honda person for 3 years now...i always wondered exactly what the v-tech is all about and what it means? i think it has something to do with the cam lobes but never knew the right answer. someone fill me in thanks
Modified by BIGPAPAWACK at 4:02 PM 8/21/2008
Old Aug 21, 2008 | 02:59 PM
LastGenEK's Avatar
Default Re: v-tech? (BIGPAPAWACK)
VTEC
Variable timing electronic control
Yes it does have to do with the cam lobes
Welcome to Honda-Tech.com
Old Aug 21, 2008 | 03:02 PM
Default Re: v-tech? (LastGenEK)
how does it work then?
Old Aug 21, 2008 | 03:36 PM
KooK's Avatar
Mustang Sally
Vtec is similar to a turbo, what the difference is, is that it is built into the head instead of externally like you would see on anybody elses car. When Vtec spools, it spools much quicker and you can program in when and how hard it spools.
However, Vtec as well as turbos really don't give you any extra power, the extra power comes from a more aggressive camshaft grind that it takes to make these things work properly.
KooK's Avatar
Mustang Sally
Default Re: v-tech? (KooK)
Vtec just spooled yo.
http://auto.howstuffworks.com/question229.htm
Old Aug 22, 2008 | 08:10 AM
LastGenEK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KooK &raquo;</TD></TR><TR><TD CLASS="quote">Vtec is similar to a turbo, what the difference is, is that it is built into the head instead of externally like you would see on anybody elses car. When Vtec spools, it spools much quicker and you can program in when and how hard it spools.
However, Vtec as well as turbos really don't give you any extra power, the extra power comes from a more aggressive camshaft grind that it takes to make these things work properly.</TD></TR></TABLE>
Haha your crazy
^read the link good info!
Old Aug 22, 2008 | 02:04 PM
ExospeedAMcrx's Avatar
I hope your not serious.
Old Aug 23, 2008 | 10:36 AM
KooK's Avatar
Mustang Sally
Default Re: v-tech? (ExospeedAMcrx)
I'm super duper serious. It's what top fuel dragsters use, they don't shift into second, they hit Vtec.
Old Aug 23, 2008 | 05:04 PM
Boostage's Avatar
Default Re: v-tec? (BIGPAPAWACK)
http://www.youtube.com/watch?v=AcT_ZyY3F0k
Old Aug 31, 2008 | 10:07 AM
preludepower420's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KooK &raquo;</TD></TR><TR><TD CLASS="quote">I'm super duper serious. It's what top fuel dragsters use, they don't shift into second, they hit Vtec.</TD></TR></TABLE>
LOL your hilarious man .
Old Aug 31, 2008 | 10:28 AM
kalm_traveler's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BIGPAPAWACK &raquo;</TD></TR><TR><TD CLASS="quote">ok stupid question being i am a honda person for 3 years now...i always wondered exactly what the v-tech is all about and what it means? i think it has something to do with the cam lobes but never knew the right answer. someone fill me in thanks
Modified by BIGPAPAWACK at 4:02 PM 8/21/2008</TD></TR></TABLE>
VTEC (there is no H, no K, no hyphen).
Variable valve-Timing-and-lift Electronic Control
It is pretty much exactly what the name implies - it varies valve timing and lift.
You were right about the cams. Essentially, you look at a VTEC cam and see that each cylinder will have 3 intake lobes instead of just 2 (DOHC VTEC systems have 3 exhaust lobes as well).
an electrically-activated solenoid allows a hydraulic system to lock the rockers to an additional assembly which is moved by the 3rd cam lobe - so you can near instantly go from a mild street lobe to a more wild race lobe for higher RPM power.
Old Aug 31, 2008 | 11:19 AM
01_CLtypeS's Avatar
http://www.teamdelsol.com/tech...vtec/
Old Aug 31, 2008 | 12:49 PM
GustavoO's Avatar
Default Re: v-tec? (01_CLtypeS)
from what i understand vtec is this little pin that pushes into the camshafts to lock up all three little lobes into place holding the intake and exhaust valves open for a longer amount of time at a certain pre set RPM....
Old Sep 1, 2008 | 11:21 AM
DonF's Avatar
How do I make this my sig.?
Old Sep 2, 2008 | 08:16 AM
AllMotorRandy's Avatar
Default Re: v-tech? (DonF)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DonF &raquo;</TD></TR><TR><TD CLASS="quote">
How do I make this my sig.? </TD></TR></TABLE>
lol
Old Sep 2, 2008 | 08:58 AM
LastGenEK's Avatar
Default Re: v-tec? (GustavoO)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GustavoO &raquo;</TD></TR><TR><TD CLASS="quote">from what i understand vtec is this little pin that pushes into the camshafts to lock up all three little lobes into place holding the intake and exhaust valves open for a longer amount of time at a certain pre set RPM.... </TD></TR></TABLE>
ITs a Pin that locks the rockers together not the cam
But you have the right idea
Old Sep 2, 2008 | 10:26 AM
GustavoO's Avatar
Default Re: v-tec? (LastGenEK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LastGenEK &raquo;</TD></TR><TR><TD CLASS="quote">
But you have the right idea </TD></TR></TABLE>
thats what i said isnt it, a pin that pushes into the cam to lock up the lobes?
Old Sep 2, 2008 | 10:36 AM
thats what i said isnt it, a pin that pushes into the cam to lock up the lobes?</TD></TR></TABLE>
it doesn't push into the cams.
it locks the 3 rocker arms together. a camshaft is just 1 piece.
Old Sep 2, 2008 | 01:44 PM
GustavoO's Avatar
Default Re: v-tec? (kalm_traveler)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kalm_traveler &raquo;</TD></TR><TR><TD CLASS="quote">
it locks the 3 rocker arms together. a camshaft is just 1 piece.</TD></TR></TABLE>
oooh ok, i get you my bad, lern something new everyday.
Old Sep 2, 2008 | 06:23 PM
base-op.1320's Avatar
lol - Oh wise one KooK (aka mustang sally) can you explain more of your great theoretical findings with us about some of the other mechanical functions of a car.
Old Sep 3, 2008 | 10:52 PM
424racer's Avatar
Default Re: v-tec? (base-op.1320)
maybe this will help a little..
Old Sep 4, 2008 | 03:09 PM
LastGenEK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by base-op.1320 &raquo;</TD></TR><TR><TD CLASS="quote">lol - Oh wise one KooK (aka mustang sally) can you explain more of your great theoretical findings with us about some of the other mechanical functions of a car.</TD></TR></TABLE>
Im also interested in your idea haha
Floyd91
15
Apr 14, 2020 09:51 PM
tvman
Oct 31, 2005 07:08 PM
timdog5984
11
Jul 22, 2005 12:00 AM
Threshld1
Jul 13, 2002 10:35 PM
allmotorEG-SI
Jun 4, 2002 11:47 AM
