itr oil cooler
Old Aug 9, 2008 | 09:38 AM
ITR-EKcoupe's Avatar
Default itr oil cooler
bought a itr motor with a spun rod bearing. right now im in the process of rebuilding the bottom end with forged internals. when i took the pan off there was quite a bit of very fine shavings. i know i have to replace the oil pump as thats just a given but what about the oil cooler on the backside of the block??? just got off the phone with the acura dealership an the oil cooler is 779 bones
why the heck is it so expensive???
Old Aug 9, 2008 | 02:22 PM
slowcivic2k's Avatar
Default Re: itr oil cooler (ITR-EKcoupe)
Flush the cooler out, there is no reason to replace it unless it failed internally.
Old Aug 9, 2008 | 02:57 PM
Default Re: itr oil cooler (slowcivic2k)
what would be the best way to flush it?? i have a solvent wash tank would that work ok??
Old Aug 9, 2008 | 03:45 PM
Yes that will work fine.
Old Aug 19, 2008 | 09:23 PM
just wondering if anyone knows if the oil goes into the cooler then through the filter or vise versa?
Old Aug 21, 2008 | 06:56 PM
anyone??
Old Aug 21, 2008 | 07:16 PM
fourthgenhatchB17's Avatar
Im not sure as far as order of oil travel goes but id **** can the cooler (some refer to it as an oil warmer). No sense in taking the risk of particles/shavings being trapped inside. Your motor can live without it. You can also buy one from someone who has removed their's. I took them off of every motor i had and ran an external air to oil cooler.
edit: Actually, if im picturing it in my head correctly, the oil woulkd pass thru the cooler first.
Old Aug 22, 2008 | 05:23 AM
IN VTEC's Avatar
Cooler first then through the filter element.
pjr710
Feb 6, 2009 10:23 AM
4everVtec
Dec 18, 2007 10:26 AM
eluam
Jun 23, 2007 06:09 AM
jdmcx
Apr 7, 2004 06:38 AM
92TypeR
Jul 5, 2002 04:55 PM
