Help removing roll pin from shifter rod
I tried to buy a 8mm drift tool but could not find any at local shops. I also tried to use a 8mm bolt but the pin doesnt move and its hard to keep the bolt in one spot because of the threads. Is there any other way?
A punch will work. Harbor Freight has some cold steel punches that are really cheap (literally) but they are strong enough to get the job done.
Actually, I haven't broken one of them yet.... And I do beat the hell out of them.
5/16 or 8mm punch straight shaft punch. Use a mini sledge and give it a good wack.
I tried this technique but it's pretty fustrating. BFH and punch is the way to go!!
http://www.performanceforum.co....html
B series or D series ?
D series I do from the top. Long 3/8 extension with a 7/32 hex on the 3/8 drive. 5lbs hammer. I think the tranny goes in 2nd gear, ?
Feed the long extension down by the throttle body with the 7/32 hex bit on it, on to the top of the bitch pin. I think you figure out the rest.
its on a d series. i managed to finally get that bitch out but it took forever. i used a straight punch. i was wondering y it was so hard to take out until i saw that it was a spring. thanks for the advice.
USDM 4G VTEC
13
Nov 30, 2002 08:30 PM
