Cusco LSD Help
Old Jul 23, 2006 | 03:35 PM
V8whaaa's Avatar
Default Cusco LSD Help
Hey guys i bought a Cusco LSD from a Guy on Honda-Tech
he said it was for B16/GSR Trannies, so i bought the LSD figuring it would fit my SI...now i go to install my ring gear from my Open Diff..and Inside Diameter of the LSD is too small to fit this LSD....
Cusco's website says
part# LSD328B15 is for Civic/Integra B16A/B18C 93.5-up i assume
is there any differences in the GSR/Type R ring? other than Ratios...and if so can i buy a ring gear to fit this LSD with the same Gear Ratio that my SI has now?
Old Jul 23, 2006 | 07:48 PM
not so civic's Avatar
From: gravity rides everything...everything will fall, se GA/ne FL
Default Re: Cusco LSD Help (V8whaaa)
i gathered you have a gsr/itr lsd and not a "b16/gsr". since you have a '00 si and the i.d. on your stock ring is too small for the cusco, then you need a gsr/itr 4.40 ring.
Old Jul 24, 2006 | 02:15 PM
V8whaaa's Avatar
Default Re: Cusco LSD Help (not so civic)
icic...do you have the 4.4 final drive i need forsale?
twentyhurtz
Transmission & Drivetrain
Aug 9, 2009 10:21 AM
Ti3d in
Mar 16, 2009 02:46 PM
zimmy709
Jun 25, 2008 04:06 PM
vti444
Jun 20, 2005 03:33 PM
