Tap/Die for AN fittings?
Old Jul 21, 2006 | 02:26 AM
Enzo Speed's Avatar
Default Tap/Die for AN fittings?
I had a local shop weld an AN fitting to my intake manifold, but the guy messed up/melted the threads a little bit in one area. What kind of die can I use to fix it? Would a standard die work? The fitting is AN-8.
Old Jul 21, 2006 | 12:59 PM
Enzo Speed's Avatar
Default Re: Tap/Die for AN fittings? (Enzo Speed)
Nothing?
Old Jul 21, 2006 | 02:07 PM
silentdaredevil2's Avatar
use a 3/4-16 die
Old Jul 21, 2006 | 05:50 PM
Enzo Speed's Avatar
Default Re: (silentdaredevil2)
So the thread/pitch on AN fittings is standard? That's what I was hoping.
Old Jul 22, 2006 | 06:22 AM
sure is, here is a guide if you ever need it
http://www.holley.com/data/Tec...s.pdf
Old Feb 10, 2026 | 09:08 AM
s2kteckie's Avatar
I know this is old, but I saw it was unanswered when I was searching for the same tools. You can find tap and die kits with lapping tools at knechtionrepair.com
Type 56
Oct 4, 2016 08:49 AM
98civicEX
Aug 13, 2009 02:11 PM
Keyhole
Welding / Fabrication
Aug 4, 2005 05:27 PM
sadangryboi
May 3, 2005 05:38 PM
rioninja
Nov 20, 2002 11:43 PM
