Advise on sleeves
Old Jul 24, 2006 | 04:10 PM
MAFDARK's Avatar
Default Advise on sleeves
need some opinions. Does this look like "normal piston wear" or slap?
Also, do you think it will need or a bore/hone or what?
Old Jul 25, 2006 | 03:14 AM
methanemotorworks's Avatar
Default Re: Advise on sleeves (MAFDARK)
just bored it out and hone it, save youself a big headache, everytime you pop out the piston you'll most likely have to bore it out and hone it and get new rings, and no thats not normal, especially the marks on the side of the sleeve
Old Jul 25, 2006 | 08:43 AM
doublejz's Avatar
Default Re: Advise on sleeves (methanemotorworks)
i wouldnt say thats slap or normal wear. it almost apears the the piston or cylinder aren't completely round. What i have saw from piston wear is a big area that is warn no a couple spots like that. if your just tring to get it back to normal i would just hone it. but if you're building it up bored it out 20 over and slap some new piston & rings in it. You may want to check your clearance on your bearings too... it may have too much causing the pistons to be slightly digging into the cylinder wall. good luck
Old Jul 25, 2006 | 02:21 PM
projectTeG's Avatar
no thats a clearnace problem
Old Jul 25, 2006 | 02:39 PM
MAFDARK's Avatar
Default Re: (projectTeG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by projectTeG &raquo;</TD></TR><TR><TD CLASS="quote">no thats a clearnace problem</TD></TR></TABLE>
care to explain?
Old Jul 25, 2006 | 03:10 PM
projectTeG's Avatar
as the stated before it could be a out around cylinder, a bad ring gaps...or it could be from running rich and washing the cylinder walls out.
pokmijn
Jul 14, 2007 07:11 PM
si_bat
Jun 24, 2007 05:11 PM
95blackEG
May 23, 2007 02:50 PM
Sliced Beard
Jan 22, 2004 06:55 PM
MrCrx
Jun 17, 2003 09:08 AM
