gross polluter...can someone help?
Old Jul 18, 2006 | 04:38 PM
EFb18b's Avatar
Default gross polluter...can someone help?
Here is the diagnostic the emissions station gave me. I also got a pamphlet on what the top ten reasons I failed are. Anyway I failed hydrocarbons and CO but my NOx was fine surprisingly. Any help will be appreciated. I have until November 15th to clean up my act
Old Jul 18, 2006 | 05:12 PM
SILVEREJ7's Avatar
i would almost say a good tune up oil change and make sure your cat is good. other than that im not sure where i live i dont have to worry about emissions checks. i know id fail horribly if i had to.
Old Jul 19, 2006 | 08:45 AM
thesmogman's Avatar
Default Re: (SILVEREJ7)
HC = unburnt fuel
CO = poorly burnt fuel
Could be's
O2 sensor
Air filter
Tune-up
clogged injectors
fuel pressure
If your HC's are up usually the NOx is down. By the way NOx is caused by high combustion temp above 2500 degrees. The HC's keep the combustion temps down.
Old Jul 20, 2006 | 04:07 AM
EFb18b's Avatar
Default Re: (thesmogman)
thanks for teh response. I'll check out a few things
Old Jul 20, 2006 | 04:42 AM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: (EFb18b)
If you have an adjustable FPR, or a standalone ECU, you can lean your car out.
Most swapped cars fail because of HC's.
Old Jul 20, 2006 | 04:48 PM
EFb18b's Avatar
Default Re: (JDM_Ej)
just out of curiousity, why is that? I mean if you're using the same ecu that the engine requires shouldn't run the same as a stock motor?
nabs.no.abs
Nov 19, 2013 06:47 PM
Amed Irizarry
11
Dec 4, 2011 07:01 PM
thewrai6th
May 17, 2011 01:00 PM
7mile
Oct 8, 2008 09:47 AM
andrewasf77
Dec 7, 2002 10:36 PM
