sohc question
Old Jul 20, 2006 | 07:27 PM
TehMan's Avatar
Default sohc question
if i put a skunk2 or edelbrock intake manifold on a stock d16z6 would it gain power or lose power? i have a guy saying that it would lose power because its to much air for that little motor...someone help me
Old Jul 20, 2006 | 07:50 PM
Jim Truett's Avatar
Default Re: sohc question (TehMan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TehMan &raquo;</TD></TR><TR><TD CLASS="quote">if i put a skunk2 or edelbrock intake manifold on a stock d16z6 would it gain power or lose power? i have a guy saying that it would lose power because its to much air for that little motor...someone help me</TD></TR></TABLE>
I assume it would shift the powerband higher, so you might lose a little torque. Because your engine is stock I would recommend a D16y8 manifold for simplicity. The S2 hits the proportioning valve in the EG chassis, and people have seen power gains with the y8 mani on a z6.
I have the S2 Pro Series manifold on my D17Z6 build, and it seems to work well, but I'm boosted too.
Old Jul 20, 2006 | 08:18 PM
SuzukaBlueAP2's Avatar
Default Re: sohc question (Jim Truett)
It's difficult to say how exactly it's going to affect the power in a plus or minus sense, but I agree with the post above that it is going to work with a different powerband.
On a stock D16, my guess is that it's going to lose some torque and maybe pick up a pony or two in the top end.
Old Jul 20, 2006 | 09:05 PM
TehMan's Avatar
Default Re: sohc question (SuzukaBlueAP2)
it's in a delsol. we have the room the intake manifold is already in the car. but it ran an 11 in the 1/8th of a mile.
Old Jul 22, 2006 | 02:22 AM
Bense's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TehMan &raquo;</TD></TR><TR><TD CLASS="quote">it's in a delsol. we have the room the intake manifold is already in the car. but it ran an 11 in the 1/8th of a mile. </TD></TR></TABLE>
for d-series to gain power, you have to tear them apart and build them up.
either that or boost.
Old Jul 22, 2006 | 12:52 PM
d16vtecx's Avatar
Default Re: sohc question (Bense)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bense &raquo;</TD></TR><TR><TD CLASS="quote">
either that or boost.</TD></TR></TABLE>
this is true
the s2 micht give you some gains but the edelbrock is too much for a stocker
Old Jul 22, 2006 | 01:59 PM
b18sihatch's Avatar
Default Re: sohc question (d16vtecx)
most of those are made for higher rpm power gains not so much lower, so yes you should loose lower end power to gain higher end power.
and i also sendond the useage of built up high compression d series or d series with turbo, you need something that will push and pull the air ie: high compression pistons, or turbo
Old Jul 22, 2006 | 07:33 PM
Bense's Avatar
Default Re: sohc question (b18sihatch)
yep, either that or gears. But lets not get TOO carried away here, this is been covered extensively
leondx
10
Mar 7, 2010 12:36 PM
julianbc2
May 3, 2009 04:37 PM
94HONDAHEAD
Feb 21, 2007 07:59 PM
Honda_Tengoku
Sep 9, 2004 03:26 PM
Marauder
Mar 31, 2003 07:22 AM
