B18A/B Manifold & Throttle body compatibility (No map sensor)
Old Jul 20, 2006 | 04:00 PM
Takumi Fujiwara's Avatar
Default B18A/B Manifold & Throttle body compatibility (No map sensor)
I mated my B18B (94 Integra) throttle body to a B18A intake manifold (As far as I know it is a B18A manifold).
I suspect I am suffering from severe vacuum leak due to this. The throttle bodies ARE different in design in regards to placement of the FITV and such. Anyhow I tried to put the B18A throttle body back on it's B18A intake manifold and now i see that there is NO map sensor, nor is there a spot where I could even mount the one off my B18B throttle body.
Is there a solution here? Or should I drain the coolant and swap intake manis (An option I'm not too fond of, but I will if it is the best option).
The ECU I am running is a 94 LS map...
Old Jul 21, 2006 | 08:32 AM
97grnrs's Avatar
Default Re: B18A/B Manifold & Throttle body compatibility (Takumi Fujiwara)
did u use a new TB gasket? i have a b18B intake mani and im usin a b18a TB. so it should work fine.
WojtekG
Sep 27, 2018 10:18 PM
PR8urVtec
Feb 4, 2013 02:05 PM
Spug
Jan 17, 2012 02:45 PM
Takumi Fujiwara
Jul 20, 2007 08:50 AM
ChaseIntegra
Oct 4, 2003 12:39 PM
