transmission pops out of gear???
Old Jul 20, 2006 | 10:45 PM
707EF8's Avatar
Default transmission pops out of gear???
I just bought a del sol with the stock b16 in it. Everything is ok except for a missing Vss sensor. Also everytime I pop it into fifth gear and drive for about 10-20 seconds it pops out of gear. does anybody know why? could it be that the VSS is missing? please help.
Old Jul 21, 2006 | 12:32 AM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: transmission pops out of gear??? (707EF8)
Your transmission would not pop out of 5th gear because of a VSS sensor missing.
Old Jul 21, 2006 | 05:37 AM
JDM knowledge's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 707EF8 &raquo;</TD></TR><TR><TD CLASS="quote">I just bought a del sol with the stock b16 in it. Everything is ok except for a missing Vss sensor. Also everytime I pop it into fifth gear and drive for about 10-20 seconds it pops out of gear. does anybody know why? could it be that the VSS is missing? please help.</TD></TR></TABLE>
Syncro is fugged.
Old Jul 21, 2006 | 07:11 AM
707EF8's Avatar
Default Re: transmission pops out of gear??? (JDM knowledge)
so is the syncro the only problem it can be? or just the most common reason of the gear poppin out? can it be anything else?
Old Jul 21, 2006 | 10:08 AM
snatch's Avatar
Why would a synchro have anything to do with it? That's just for lining everything up and matching the two different speeds of the gears when changing gears.
Sounds to me like it's a bent/almost broken shift fork.
Old Jul 21, 2006 | 11:36 AM
Honda Bull's Avatar
Default Re: transmission pops out of gear??? (******)
A friend's tranny had this issue and it had nothing to do with the shift forks, as they were still in great condition. It's probably the synchro/sleeves.
Old Jul 22, 2006 | 02:18 AM
Bense's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM knowledge &raquo;</TD></TR><TR><TD CLASS="quote">Syncro is fugged.</TD></TR></TABLE>
While I am sure that you're an advocate of that "JDM Knowledge" You are still wrong.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ****** &raquo;</TD></TR><TR><TD CLASS="quote">Why would a synchro have anything to do with it? That's just for lining everything up and matching the two different speeds of the gears when changing gears.
Sounds to me like it's a bent/almost broken shift fork. </TD></TR></TABLE>
Yep, either that or fucked up dog teeth
Fucked up dog teeth:
I don't feel liek explaining right now
*yawns
Old Jul 22, 2006 | 06:26 AM
707EF8's Avatar
Default Re: transmission pops out of gear??? (Bense)
man this sucks. oh well, should i take it to a shop for them to repair it? or should i just buy another trans? what do you guys think
Old Jul 22, 2006 | 06:39 AM
Honda Bull's Avatar
Whoops... I had the wrong terminology. *Blushes*
Bense is correct. 'Dogteeth.' Due to the material they have the ability to round off very easily. I figured the synchro and the dogteeth would be considered of the same. Broken synchro springs do weird **** too.
Old Jul 22, 2006 | 09:39 PM
not so civic's Avatar
From: gravity rides everything...everything will fall, se GA/ne FL
"synchro spring"
Old Jul 23, 2006 | 12:50 AM
4door93civic's Avatar
Default Re: transmission pops out of gear??? (not so civic)
this is a simple fix. check your tranny fluid i am willing to bet it is low.i found out the hard way when a b series tranny is low on fluid it will pop out of fifth.
Old Jul 23, 2006 | 12:28 PM
707EF8's Avatar
Default Re: transmission pops out of gear??? (4door93civic)
ok i will check the fluid... i just bought the car and found out that the vss was missing. i replaced the vss right away but didnt add trans fluid. probably when i drove it home some of the trans fluid left the tranny thus causing fifth to pop out. im going to check now
Old Jul 23, 2006 | 02:12 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bense &raquo;</TD></TR><TR><TD CLASS="quote">
dog teeth was what i was thinking of, but i didnt know the proper terminolgy thanks. Next time come up with something original if your gonna insult me.
Old Jul 23, 2006 | 05:16 PM
707EF8's Avatar
filled the tranny with fluid... fifth works now!!! thanks for the help
Old Jul 23, 2006 | 05:29 PM
MrRealityman's Avatar
holy crap! i wish i had thought to check the oil before i destroyed my first b16 tranny. but then again it might not have been oil. cause it had no serial#
Clermont Bill
Acura TL, RL & ZDX
Jan 28, 2018 09:51 AM
jdm_DC2R
Mar 21, 2006 08:37 AM
AdamQ3B85
Honda S2000
10
May 2, 2005 02:52 PM
