Forgot to put the flatwashers on the head studs...
Old Jul 17, 2006 | 05:24 PM
HackeN's Avatar
Default Forgot to put the flatwashers on the head studs...
Just realized that I forgot to put the flat washers on the headstuds between the nut and the top of the head. Should I leave them off or put them on?
If I should put them on, should I untorque all the headstuds at once, then put the washers on, or should I undo one at a time?
If I should undo one at a time, should I do it in the loosening sequence, or tightening sequence.
Thanks for any help, its the ARP headstuds, on a D16Z6.
Old Jul 18, 2006 | 06:16 AM
Danny_EJ's Avatar
put them on!- losen them in same sequence they were tightened.
Old Jul 18, 2006 | 03:42 PM
HackeN's Avatar
Default Re: (Danny_EJ)
should I replace the head gasket or will it be ok?
Old Jul 18, 2006 | 08:28 PM
illestrolla247's Avatar
Default Re: (HackeN)
if you do one at a time youll prolly be safe but if they all come undone a the same time deff replace it its only 30 bucks and your already pretty much there
Old Jul 19, 2006 | 06:23 PM
highflyinhonda's Avatar
loosen and re-torque them in the tightening sequence and your head gasket will be fine.
Vtec04
Engine Machining & Assembly
11
Oct 31, 2017 09:26 AM
austincrx
Sep 7, 2006 09:49 AM
Day-DayC
May 18, 2006 08:51 PM
petrv
Apr 12, 2004 12:30 PM
