Start issue... no fire. Symptoms within.
Old Jul 25, 2006 | 09:17 AM
thatbluecrx's Avatar
Default Start issue... no fire. Symptoms within.
1990 b16a CRX.
Motors been in the car for at least 2 years, no problems till:
Problem/Example:
Start the car in the morning, runs fine, no issues. Get to where I'm going. Stay for a few hours. When I leave, poof, no fire. After 5-10 minutes of cranking, it'll go. No issues while driving after a tough start, and will refire perfect if I kill it after.
Theorys:
My best bet is the Full pump. Not sure...
Anyone else experiance and fix this similar issue before I waste loot?
Old Jul 25, 2006 | 12:03 PM
Da Rick's Avatar
Default Re: Start issue... no fire. Symptoms within. (thatbluecrx)
Yo, Im dealing with the same thing right now . I was on here scoping out for any info on this. Sometimes it turns on just fine, I get somewere....stop, and Nada. Then it's good to go after five to ten minutes. I didnt think about the fuel pump , but it could also be our solenoid to the starter. Someone HElP!
Old Jul 25, 2006 | 05:38 PM
civicstar's Avatar
depends, if its the fuel pump, usually itll bogg at certain higher RPMs and if the starter solinoid clicks when u try and start it. then itll be the starter
Old Jul 26, 2006 | 09:21 PM
jakscivic's Avatar
Actually the fuel filter will make your car bog at certain rpms as well. I just delt with that problem. If you dont know when the last time your fuel filter was changed then change it. And it it is a problem with starting i would bet its your starter. i dont exactly know all the symptoms of a bad starter but im sure one of them is problem starting. Just a thought
Zigory
Honda Civic (2001 - 2005)
Apr 1, 2019 08:19 AM
lif3tak3n
Jun 24, 2014 06:00 AM
keemerdadreamer
Feb 11, 2010 04:26 PM
jdavis94teg
May 12, 2009 09:28 AM
CustomTeggy44
Jul 4, 2004 03:04 PM
