oil cooler question
Old Jul 25, 2006 | 11:36 AM
mymeatb18
Default oil cooler question
im building a gsr block and i went to go put my b16a oil cooler on and that one threaded metal peice that holds it to the block is different so i was wondering if i could run the motor without that.
Old Jul 26, 2006 | 04:12 AM
mymeatb18
Default Re: oil cooler question (mymeatb18")
bump
Old Jul 26, 2006 | 04:06 PM
Wes V's Avatar
The threaded piece on the GSR is different due to it originally having an oil to water intercooler.
Remove it and get one from a Honda dealer for a B16 (Del Sol Vtec). That will allow you to install an oil filter.
I'm not sure how your oil cooler adapter is set-up, so I can't comment on that.
Wes
Old Jul 27, 2006 | 06:22 AM
mymeatb18
Default Re: oil cooler question (Wes V)
well it looks like if i take out that threaded piece it will fit because my nut is a long threaded male piece. but to take out the piece that is there can i use vice grips to take it out. i was thinkinbout not runnin it an just putting a filter straight to the block but i really want that cooler on.
Old Jul 28, 2006 | 12:53 PM
mymeatb18
bump
booboo782
Sep 23, 2010 06:30 AM
white90rexsi
Oct 27, 2006 03:25 AM
brokeHonda
Jan 9, 2006 07:23 PM
HybriDNA
Dec 27, 2002 07:12 PM
