4wire o2sensor into 5wire o2sensor hx civic?????????
Old Jul 18, 2006 | 09:27 AM
1slowcrx's Avatar
Default 4wire o2sensor into 5wire o2sensor hx civic?????????
i'm putting a d16y8 into a hx civic. i'm using the stock hx engine harness which has a 5wire o2, but the d16y8 has the standard 4wire o2.i'm also using the p2p ecu which runs the 4wire o2. how do i make it work? can i just eliminate the extra wires? if so which 1?or do i have to re-pin 4 new wires?
Modified by 1slowcrx at 5:32 PM 7/18/2006
Old Jul 18, 2006 | 04:32 PM
1slowcrx's Avatar
Default Re: 4wire o2sensor into 5wire o2sensor hx civic????????? (1slowcrx)
need help
Old Jul 18, 2006 | 05:14 PM
SILVEREJ7's Avatar
i have been told by a locl shop youd have to re-pin unless you want to chip your p2p and go with a primary o2 removal. im doing that in my hx. right now my primary o2 is unplugged. its unplugged because its burnt up and car runs like poo with it plugged in. i know skunk2 makes a program that eliminates the o2's individually see if someone there can order you the correct chip. that would be the easiest way to do it i think.
Old Jul 18, 2006 | 05:43 PM
1slowcrx's Avatar
Default Re: (SILVEREJ7)
there has be to a way to wire up the 4 wire o2.anyone know the ecu pinouts for a obd2a civic? i think i'm just run 4 external wire from the ecu to the o2. which pins for o2?
Old Jul 18, 2006 | 08:46 PM
1slowcrx's Avatar
any other solutions?
Old Jul 19, 2006 | 08:05 AM
1slowcrx's Avatar
anyone?
Old Jul 20, 2006 | 12:15 AM
1slowcrx's Avatar
bump
milkwasabadidea
Nov 20, 2011 04:24 AM
Mfoehrkolb
23
Oct 17, 2011 12:21 PM
Mfoehrkolb
Sep 15, 2011 06:45 PM
2000blackgsr
Apr 29, 2004 09:29 AM
vwandhondaboy
Jan 5, 2003 10:45 PM
