GSR rods in LS block
Old May 24, 2002 | 12:33 PM
Speedz's Avatar
Default GSR rods in LS block
was wondering what possible problems i'd run into by using the gsr/ITR rods in a LS block..
i realize they are .9mm longer than the LS, and the big end thickness is narrower than the LS.
basically the piston would be sticking up .0354 farther than stock.... but a thick head gasket might be able to take care of that problem.. and i'm thinking the bearings on the big end of the rod lip around the side to make of for the difference in width.
i'm just looking for a stronger rod than the stock LS, without spending big (over 300)
[Modified by Speedz, 9:34 PM 5/24/2002]
Old May 24, 2002 | 02:30 PM
sgT's Avatar
sgT
Default Re: GSR rods in LS block (Speedz)
wont work without a GSR crank to go with them. wont fit otherwise
Old May 24, 2002 | 06:50 PM
robbin's Avatar
Default Re: GSR rods in LS block (sgT)
There was a group buy on Eagle rods for $300. Don't know if it's still going though.
vtec-gorilla
Sep 19, 2006 06:40 PM
BlkslowCRX
12
Feb 9, 2005 10:18 PM
NathanMorris
Nov 30, 2004 10:01 AM
b18c-93
Oct 23, 2002 05:33 PM
B18C-EJ1
Jan 19, 2002 11:45 PM
