Brake Upgrade for 94 Coupe??
Old May 24, 2002 | 02:01 PM
Hybrid-B's Avatar
Default Brake Upgrade for 94 Coupe??
Does anyone know of a good brake system, that converts all 4 wheels into discs on a 94 coupe and lets you be able to still ride on 15s?
Old May 24, 2002 | 03:03 PM
JV's Avatar
JV
Who?
Default Re: Brake Upgrade for 94 Coupe?? (Hybrid-B)
You should already have front discs.......
You can swap the brakes off of a 94-01 Integra and use 15" wheels no problem.......
Old May 24, 2002 | 06:41 PM
HOOKUPS-PRO-CRX's Avatar
Default Re: Brake Upgrade for 94 Coupe?? (JV)
94+up integ or jdm sir eg will work fine
Old May 24, 2002 | 09:37 PM
Wide Open Throttle's Avatar
Default Re: Brake Upgrade for 94 Coupe?? (HOOKUPS-PRO-CRX)
http://www.fastbrakes.com
Old May 27, 2002 | 09:30 AM
Default Re: Brake Upgrade for 94 Coupe?? (Wide Open Throttle)
http://www.hookupsimporttek.com
Old May 27, 2002 | 10:39 AM
Katman's Avatar
If you have an EX coupe, then you already have Integra GSR front brakes. if you want rear disc brakes, look into some GSR rear disc brakes. It's total bolt-on application. I suggest a GSR master cylinder and booster for maximum (OEM) braking power. If you want even better braking power, look into a set of Fastbrakes..
Old May 27, 2002 | 11:01 AM
JV's Avatar
JV
Who?
Default Re: Brake Upgrade for 94 Coupe?? (Katman)
What about the wheel fitment problems everybody seems to have with these kits? Did you ever get yours straightened out?
everythingwentblack
10
Jun 12, 2008 03:43 PM
FF-Bee
Jun 12, 2006 11:57 AM
bluecivic05
May 12, 2006 10:15 AM
TedR719
Jun 23, 2004 11:08 AM
Street Ghost
Feb 16, 2003 01:31 PM
