bore & stroke
Old May 23, 2002 | 01:26 PM
THE *FOB* MOB's Avatar
Default bore & stroke
now, corrcect me if i'm wrong....bore is the size of the cylinder & stroke is the length of travel of the piston up the cylinder....thanks
Old May 23, 2002 | 01:27 PM
hybridreams's Avatar
Default Re: bore & stroke (1QKYOBER)
bore is the diameter of a cylinder, stroke is right
Old May 23, 2002 | 01:48 PM
Default Re: bore & stroke (hybridreams)
aight....thanks....next question: compression....for example: 10.6:1...now that means the piston travels up the cylinder 10.6 in. (?..is it measured in inches) for every one stroke?
Old May 23, 2002 | 02:11 PM
John's Avatar
New User
No, the CR is as follows:
Trapped Volume = (Head Gasket Volume) + (Deck Height Volume) - (Piston Crown Displacement Volume)
Now:
(Cylinder Volume + Trapped Volume) / (Trapped Volume) = CR:1
1320london
Engine Machining & Assembly
Sep 17, 2016 12:00 PM
HopperIsMyCar
Dec 7, 2011 03:50 PM
AFAccord
30
Feb 13, 2009 05:55 AM
qazaq
Jul 14, 2007 04:20 PM
Gant
May 28, 2005 08:10 PM
