b16 block w/gsr head???
Old May 22, 2002 | 06:39 PM
prjctCIVIC's Avatar
Default b16 block w/gsr head???
what would be the compreesion ration be with a b16 bottom end and a gsr head?? and would i be able to supercharge this setup??? thanks
Old May 22, 2002 | 07:49 PM
JV's Avatar
JV
Who?
Default Re: b16 block w/gsr head??? (prjctCIVIC)
http://www.bojangs.com/calculator/
http://www.c-speedracing.com/howto/c.../compcalc.html
[Modified by JV, 11:50 PM 5/22/2002]
Old May 22, 2002 | 09:22 PM
Canadian Hybrid's Avatar
That is the same setup that I am running, minus the supercharger. It seems to work ok for me. The compression would be somewhere around 10.6-10.8, depending on which B16 your using.
Colin
[Modified by Canadian Hybrid, 10:23 PM 5/22/2002]
Old May 23, 2002 | 10:28 AM
prjctCIVIC's Avatar
Default Re: b16 block w/gsr head??? (Canadian Hybrid)
the b16 is from a jdm b16a2....
Old May 23, 2002 | 11:02 AM
prjctCIVIC's Avatar
Default Re: b16 block w/gsr head??? (JV)
thanks JV, that was really helpful!!! BTW: which head gasket do i use?? gsr or b16??? thanks again
Old May 23, 2002 | 01:13 PM
mannyman's Avatar
El Veterano de Sur Califas
b16a and gsr 's use the same headgasket..... u might want to use one layer also to bump up the compression a bit more.
manny
SPOON_BeIgHtEeNsEe
May 9, 2007 06:19 PM
beaneg6
Aug 4, 2005 02:37 PM
.ShawnD.
21
Jul 17, 2003 08:15 PM
Kataku2K3
Sep 14, 2002 11:30 PM
