Startup problem, please help
Old May 24, 2002 | 07:07 AM
rbf351's Avatar
Default Startup problem, please help
first let me tell you guys what i've done to the car, cause that might be causing the problem
i have a 2000 Si with CTR cams, CTR ECU, ITR Valve Springs/Retainers, ITR intake Manifold, ITR Fuel Rail, ITR CAI, JDM ITR 4-1 Header, 2.5 in/out carsound cat. B & M FPR set to 40PSI with vaccum hose off.
now here's the problem
everytime i start the car it will try to die(drop down to 300-100 rpms) i try and press the gas pedal to bring it back up, but it's like the cable isn't even there.
recently my cat broke and is rattling. when i am driving the car runs perfectly. i can take it up to 9100 rpms as indication by the ITR cluster that i put in.
i don't want to start putting the old engine parts back in unless i have to.
someone please help me
Old May 24, 2002 | 08:47 AM
rbf351's Avatar
Default Re: Startup problem, please help (rbf351)
anyone?
i'm thinking too much fuel
would i be able to fix this with a VAFC?
Old May 24, 2002 | 11:17 AM
Dutchie's Avatar
Have you tryed playing with the fuel pressure yet? If you have, the first thing I would do is swap a stock FPR on it. For some reason I have seen numerous Hondas run shitty from the B & M.
Old May 24, 2002 | 11:53 AM
rbf351's Avatar
Default Re: Startup problem, please help (Dutchie)
i never had a problem with the B & M, it's been on the car for year,and it didn't cause any problems, i'll try and see if i change it tonight if it fixes anything
hectic57
Mar 20, 2008 05:08 PM
asianeric
Feb 1, 2006 02:48 PM
That Dood
Jan 29, 2004 03:55 PM
CivicEK.PDX
Sep 19, 2002 11:03 PM
