B20Z swap in a Civic EX 96 - Problems!!
hi!
My engine swap is done but I have a problem with the fuel injection... The engine is running lean and we juste verify all the sensors, hoses and ecu diagram...
No check engine light...
I have a b20Z 00 with integra RS injection, ecu, tranny, etc...
What could be the problem??? Ecu?? Injectors?? TPS??
I will install for sure a FPR, but where the problem come from???
Every peoples who are running the same engine, did the same thing and everything is ok...
Please help me!! I'm riding in a VW golf 91 for 2 weeks and i want my car back!!!
Frank@clubcivicquebec.com
Other peoples who are using this setup don't use the Integra fuel pump, the stock fuel pump cans run a H22a so why not a b20z...
I will buy the FPR but it will not solve the cause of the problem...
I still looking for an answer...
It's kinda bizarre...
accually the stock civic pump cannot flow well enough for a B18 or a B20.
a freind of mine with a B18C swap into a civic falls right on it's face and practically cuts out at the same time the A/F guage pegs lean and fuel pressure drops.........i dunno maybe his pump was bad but he changed it to an integra pump and it was fine.
anyway get a fuel pressure guage and check out the situation with your fuel pressure
oneheadlight
Nov 5, 2017 06:46 AM
