Help bleeding brakes.
Old May 23, 2002 | 06:21 AM
ITR1071's Avatar
Default Help bleeding brakes.
My brakes suck! I was told I needed a new master cylinder. I got it and put it on, but my Haynes manual told me to bench bleed the cylinder. I didn't have the supplies to do it so I just put it on and was going to bleed each brake individually. Is this going to work? Also, does the car have to be on to bleed the brakes.
Old May 23, 2002 | 06:46 AM
Kalokohan's Avatar
New User
Default Re: Help bleeding brakes. (undercoverSI)
No, the car should be off and level to the ground when bleeding brakes.
Old May 24, 2002 | 04:29 AM
Mista Bone's Avatar
D Tranny Guru
you HAVE to "bench bleed" or else you'll never get all the air out of the MC.
Old May 25, 2002 | 11:14 AM
90TegRex's Avatar
Default Re: Help bleeding brakes. (Mista Bone)
Please forgive my ignorance, but what is "bench bleeding." I'm planning on upgrading my brakes on my crx, and need to change my MC too. Thanks
Old May 25, 2002 | 02:46 PM
Perfectionist's Avatar
Default Re: Help bleeding brakes. (davija)
Bench bleeding basically is getting brake fluid into the the MC before mounting it in the car. This speeds up and simplifies the rest of the bleeding procedure.
90 ef
Oct 29, 2009 12:03 PM
asnboi512
Suspension & Brakes
Jun 30, 2009 10:07 PM
Harleyfxdl80
Oct 1, 2006 05:20 PM
shutta
May 13, 2006 02:32 PM
DriveSideWays
Aug 7, 2004 05:34 AM
