B20/VTEC head gasket trouble:
Old May 24, 2002 | 09:30 AM
dbman96's Avatar
New User
Default B20/VTEC head gasket trouble:
Building a B20B block / B18C1 head combination and wanted to be sure what HG to use. I called Race Engineering (Cometic dealer) and the guy I spoke with said I need to match the gasket to the HEAD (GSR), but everything else I've seen says I should be running a gasket to match the BLOCK. Help me out here!
Just to add to this - I'm looking at Race Engineering's list of HGs right now and they DO have a "B18C / B16A" 84mm head gasket but they do not appear to have a B20 head gasket anywhere. I know the dowel pins won't line up on a VTEC head gasket so what should I do?
Old May 24, 2002 | 12:23 PM
AllMotorMadness's Avatar
Default Re: B20/VTEC head gasket trouble: (dbman96)
you can just use a stock honda crv headgasket, it'll be fine but if you had the block bore/hone to 84.5mm, you can just use a 85mm cometic headgasket
Old May 24, 2002 | 02:29 PM
sgT's Avatar
sgT
Default Re: B20/VTEC head gasket trouble: (AllMotorMaddness)
head gasket always has to match the block, not the head
Old May 24, 2002 | 06:54 PM
HOOKUPS-PRO-CRX's Avatar
Default Re: B20/VTEC head gasket trouble: (sgT)
match the head gasket to the block.(period) but use the gsr head bolts with gsr torque specs
Old May 24, 2002 | 07:06 PM
Halo's Avatar
Default Re: B20/VTEC head gasket trouble: (HOOKUPS-PRO-CRX)
What about a 84mm hg with an 84.5 bore?
Old May 24, 2002 | 07:08 PM
Default Re: B20/VTEC head gasket trouble: (Halo)
stock honda gaskets are always 1mm larger than the bore of the block you will be fine
Old May 25, 2002 | 12:23 AM
dbman96's Avatar
New User
Yeah I was a little scared when the Race Engineering guy was pointing me in the wrong way, but it looks like Cometic has already addressed CRVtec engines and they're selling a HG specifically for such a conversion.
Old May 26, 2002 | 09:08 PM
mannyman's Avatar
El Veterano de Sur Califas
if u bore your b20 to 85mm, then yes u gave to get the cometic 85mm b20 hg. Now if you have 84.5 mm pistons, than u can use stock hg, becasue the stock hg when crushed actually opens to 84.5mm. I highly doubt that stock hg come 1mm over.
manny
Old May 27, 2002 | 09:19 AM
Default Re: B20/VTEC head gasket trouble: (mannyman)
sorry bro but my bore size is 85.5mm and i use stock headgaskets.PERIOD! they are 1mm oversized from the factory call rich at R.S an ask.
crv-techu
Mar 11, 2006 04:05 PM
turboex
Nov 20, 2002 04:40 PM
dbman96
May 24, 2002 11:23 AM
