Mechanical Oil Pressure Gauge HELP.
Old May 22, 2002 | 09:53 PM
Image's Avatar
Default Mechanical Oil Pressure Gauge HELP.
I have a mechanical oil pressure gauge and need some help installing it. It is going into a 92 civic si. I need help locating an oil line or somewhere to tap into in the engine compartment to get the thing working.
Any help will greatly appreciated. Thanks alot H-T peps.
Old May 22, 2002 | 10:27 PM
kinesistech's Avatar
Default Re: Mechanical Oil Pressure Gauge HELP. (Image)
Just to the left of your oil filter is a one wire switch. Its for the oil light. It is trash, basically it lights the idiot light when oil pressure is 3psi. Thats way too low for you to do anything at that point. Just removed that thing. The hole in the block is 1/8 BSP and your gauge came with a 1/8 NPT. They are almost exactly the same except the taper of the threads is smaller for BSP. That means your fitting will only go in about 3 threads. Get a 1/8 NPT tap and make that hole the right size, otherwise you may damage the threads. Its easy, dont worry.
Old May 23, 2002 | 02:44 AM
rainforest's Avatar
Default Re: Mechanical Oil Pressure Gauge HELP. (kinesistech)
ah dont hate just tee it you can still run the oil pressure sendor sensor. spend the extra dollar on the tee.
Old May 23, 2002 | 06:39 AM
Crazydave's Avatar
Default Re: Mechanical Oil Pressure Gauge HELP. (rainforest)
Come on guys .... do it right...
buy a BSP to NPT adaptor...
don't have the TEE hang off the block.. this will only cause problems later on...
I would recommend an electric guage over a mechanical one.
hot pressurized oil in the cabin = no good
Old Nov 12, 2004 | 04:49 PM
thrty8street's Avatar
Default Re: Mechanical Oil Pressure Gauge HELP. (Crazydave)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crazydave &raquo;</TD></TR><TR><TD CLASS="quote">Come on guys .... do it right...
where can i buy this adaptor?
Old Nov 12, 2004 | 04:56 PM
Dan GSR's Avatar
Default Re: Mechanical Oil Pressure Gauge HELP. (thrty8street)
http://www.fast-turbo.com/Turbolines.html
Firewall Oil Supply Distribution Line Kit
best deal ive seen, it comes with EVERYTHING
i'm using this kit, and highly reccomend it
Old Nov 12, 2004 | 10:12 PM
mmuller's Avatar
Mad Scientist
as everybody is saying, make sure you have a distribution block:
you can get nicer blocks/lines/adapters here:
http://www.mcmaster.com/
Old Nov 13, 2004 | 08:56 AM
dunkd's Avatar
DO NOT PUT THE SENDOR ON THE BLOCK, RUN TO THE FIREWALL!
that sender unit is fairly heavy and the vibrations of the motor will cause the block to crack. i have read about it happening a lot and never really believed it...
then it happened to a friend, and now he has JB weld on the back of his black.
afplayboy17
Oct 6, 2007 10:39 AM
cjmitthun
75
Nov 21, 2006 08:35 PM
Turbo_y8
Apr 21, 2005 04:23 PM
a1320honda
10
May 22, 2004 03:56 PM
hatchmonkey92
Aug 19, 2003 10:08 AM
