is it ok to ride on the bumpstops?
Old May 26, 2002 | 11:55 AM
bretx0r's Avatar
Default is it ok to ride on the bumpstops?
i just picked up a set of koni yellows for my ground control, so i made the koni ground control setup, it looks sortof like a full coilover setup. anyway, first off, i was riding very low, like slammed at the lowest i could get it, when i realized that i wanted to handle better, and i didnt want to blow my new $500 investment right off the bat. So i raised my car up about an inch, and i checked to see how much travel i have and im still riding on the bumpstops WTF? so im just wondering if its ok to ride on the bumpstops because i see a lot of people here who are approximately the same drop as me. And will Koni yellows be able to take such a drop for a long period of time? thanks.
and just for the record, i am in love with these shocks, they make my car handle and ride like a dream.
[Modified by bretx0r, 8:58 PM 5/26/2002]
Old May 26, 2002 | 12:01 PM
TurboSedan's Avatar
New User
Default Re: is it ok to ride on the bumpstops? (bretx0r)
Did you trim the bumpstops? It is NOT ok to ride on them. This will damage your shocks and pride!
Old May 26, 2002 | 12:07 PM
bretx0r's Avatar
Default Re: is it ok to ride on the bumpstops? (97CivicFerio)
yes, i trimmed them, cut them half off
if im not riding on them, i am coming very close because i was riding lower before so i am not riding on them as much (?)
[Modified by bretx0r, 9:08 PM 5/26/2002]
Old May 26, 2002 | 02:00 PM
Super7's Avatar
NO.
The bumpstops are at the end of your suspension travel. Riding on them effectively limits how well your suspension can react as you drive down the road. This will not only damage the suspension components, but it is also DANGEROUS. Just because others are doing it does not make it ok.
Old May 26, 2002 | 02:16 PM
bretx0r's Avatar
Default Re: is it ok to ride on the bumpstops? (Super7)
whats the average amount of travel between the end of the shock and the bump stop?
Old May 26, 2002 | 02:35 PM
cbrf-3's Avatar
Default ive got pro-kit & koni's
I've got about a inch of travel before my bumpstop hits and thats with the bump cut a little more than half.
Old May 26, 2002 | 02:41 PM
bretx0r's Avatar
Default Re: ive got pro-kit & koni's (cbrf-3)
how high over the tire is your car and with what size tires?
Old May 26, 2002 | 02:44 PM
cbrf-3's Avatar
Default Re: ive got pro-kit & koni's (bretx0r)
i can fit barely 2 fingers between the fender and tire. Im runnin 195-50-15's
Old May 27, 2002 | 02:17 PM
bretx0r's Avatar
ttt
Old May 27, 2002 | 03:42 PM
NismoNX's Avatar
Its not good, very dangerous and will make your new setup wear out faster.
slateEKsi
Feb 27, 2010 11:22 PM
EK k kay
Suspension & Brakes
13
Nov 30, 2005 11:51 AM
2DoorBandit
Suspension & Brakes
Nov 7, 2005 10:53 PM
doe
Jul 29, 2002 09:44 PM
96 SOHC VTEC
24
Jan 27, 2002 07:56 PM
