How to repair crank keyway
Old Mar 1, 2013 | 12:59 AM
mouab18c1's Avatar
Default How to repair crank keyway
My crank pulley came loose once and caused some damage to the crank pulley keyway on the crank. Key was shredded. Even with a new key there is slight movement. How can I repair this without tearing it apart?
I was thinking about using some jb weld to weld the key in the keyway. Any ideas?
Old Mar 1, 2013 | 04:58 AM
KeithsDAteg's Avatar
Default Re: How to repair crank keyway
Bigger keyway? Loctite on the Crank bolt
JB weld would more that likely melt down on the crankshaft gear.
Old Mar 1, 2013 | 06:59 AM
1998GsRIntegra's Avatar
Tig weld and have it recut? Or just weld the pulley on? I assume the engine is assembled and in the car? Loctite works only with the absence of oxygen so it might work.
Old Mar 1, 2013 | 07:24 AM
h2.4's Avatar
^lol weld the pulley on. I've welded cranks before. Tig weld and finish file to fit keyway.
Old Mar 1, 2013 | 09:48 AM
JB Weld is asking for a disaster.
Old Mar 1, 2013 | 10:38 AM
mouab18c1's Avatar
Yes motor is still sitting in the car. Guess the only way to fix it is pulling it out and getting it tig welded.
No I will not weld the pulley on. You gotta understand that with movement in the key way. Tdc does not line up. So like I said above guess the only option is to find a shop that will tig weld t and cut it back down.
Old Mar 1, 2013 | 03:15 PM
Desperate times call for desperate measures. Lmfao. Just depends on how ghetto you want to get. Haha
TheWalrus
May 7, 2011 06:03 AM
civikdude
Feb 13, 2009 02:17 PM
Baron55
Jun 12, 2007 05:01 AM
HonCiv
12
Nov 15, 2002 10:01 AM
