Strange Oil leak...need Help...
Old Feb 27, 2013 | 08:04 AM
Y56ITR00's Avatar
Default Strange Oil leak...need Help...
Hey guys sorry its my 1st post, but I have this strange oil leak from cylinder 2 by the headers after I changed to a Hamp oil filter. Any ideas? please help...
Old Feb 27, 2013 | 10:48 AM
Scottchy014's Avatar
Your oil filter may be constricting oil flow. Honda's can build up quite the oil pressure, especially during high rpm's. This constriction can add pressure or even a buildup of oil around your seals and gaskets. If you have old or weak seals, chances are your engine will start to cry oil. I'm not a pro but I've seen oil leaking from my vtec solenoid and distributor every time I reach high rpm's. I finally changed the o-ring and gasket. For you, I would get a different filter. Preferably Honda made.
Posted from Honda-tech.com App for Android
Old Feb 27, 2013 | 10:51 AM
Oh yeah, and check your PCV.
Old Feb 28, 2013 | 08:10 PM
Y56ITR00's Avatar
Default Re: Strange Oil leak...need Help...
Thanks Scottchy014 I'll look into that, and yea my PVC is making a loud whistling sound when the car is warmed up...I replaced it with a new OEM one and it's still doing the same high pitch whistle...
joelmatt89
Jul 16, 2011 01:30 PM
v8killaz
Nov 20, 2009 03:21 PM
racingfan
Aug 14, 2006 02:18 PM
tegman85
Apr 16, 2006 05:48 PM
Tim Martin
Feb 18, 2006 01:06 PM
