Vtec lag/sputter
Old Mar 5, 2013 | 09:55 PM
Wakeboarder482's Avatar
Default Vtec lag/sputter
So I have a 95 integra ls/vtec with the gsr head. Recently it has had a small lag right before vtec then it sputters for about 200-500 RPMs before it picks up. It is almost like a bog when it hits vtec. I have checked the ECU thoroughly and tried swapping out the distributor but still no change. If anyone has had this problem i would really appreciate the input.
Old Mar 6, 2013 | 04:28 AM
sirtef9's Avatar
Default Re: Vtec lag/sputter
Timing good? Sounds like its retarded a couple teeth
Old Mar 6, 2013 | 06:01 AM
Checked it. Timing is dead on.
Old Mar 6, 2013 | 04:46 PM
I am running a p28 chipped ecu with dc headers and a stock exhaust with stock CAT. Is it possible that the lack of air flow is a cause. I can hear the vtec kick but once it does it will lag for a moment then be good. The higher the gear, the longer the lag.
Old Mar 6, 2013 | 05:24 PM
grumblemarc's Avatar
The Grumpiest
CELs?
Old Mar 7, 2013 | 08:20 PM
Originally Posted by grumblemarc
CELs?
No. No codes come up
DarikDisease
Aug 26, 2008 01:29 PM
C1power
Jan 3, 2006 07:15 PM
SSA 1
Jul 27, 2003 09:41 PM
GreenGSR
Aug 11, 2002 06:45 AM
