Throttle Body Boring and Plate
Old Feb 17, 2013 | 07:26 PM
Veggie Man's Avatar
Icon2 Throttle Body Boring and Plate
So I wanna bore my TB out to 64mm. I'm trying to find a TB plate at 64mm. I'm having trouble finding one.
I'm wondering, if I have the TB bored out all the way through and perfectly round at 64mm would I be able to use a 64mm plate at the correct thickness, just have the screw holes drilled out and possible file it down a little to seal correctly? Or is there a method to the design of the plate?
Old Feb 17, 2013 | 07:36 PM
doood's Avatar
been there done that
Default Re: Throttle Body Boring and Plate
you have to make your own plate. send it here www.maxbore.com before you **** something up
Old Feb 17, 2013 | 08:13 PM
Veggie Man's Avatar
Im aware of maxbore. I have an extra TB to work with so I want to see if I can do this myself for cheaper.
My question still stands though.
Old Feb 19, 2013 | 05:31 PM
1998GsRIntegra's Avatar
I'll sell you one that I have that was done my maxbore if you are interested. I have no use for it. 66mm opening that tapers to a 64mm butterfly IIRC.
As far as I know, in addition to making your own butterfly, you also need to open up the gap width wise in the black bar that holds the butterfly to accomodate the larger butterfly.
As far as making the new butterfly goes, I can't really help you there. You could probably have a chunk of solid SS round bar turned down to 64mm and then get a thin piece cut off by your machine shop, but I'd imagine that by the time you pay them to hone the throttle body out and make a new butterfly for it, you'd probably be pretty close to what George@Maxbore charges.
Good luck.
Old Feb 22, 2013 | 08:37 PM
Veggie Man's Avatar
yeah but maxbore charges more for spacer and upper manifold matching. a machine shop would charge around an hour or so of time. I bet I can get all three done and a new plate for less than $100.
But right now Im pretty broke. I was gonna be able to afford modifying the tb but I think I may need a new cat converter now.
tarpus91
Engine Management and Tuning
Apr 15, 2017 04:19 PM
chrisff521
Dec 3, 2010 07:22 AM
Str8 outta Cliff
Welding / Fabrication
May 6, 2007 07:11 AM
hybridb18
Sep 11, 2003 04:59 PM
Sloth
Mar 22, 2002 01:06 PM
