strange noise from tranny.....
Old Mar 12, 2002 | 07:45 PM
E-lude78's Avatar
Default strange noise from tranny.....
When i turn on the motor, my tranny makes a loud "whirring" noise. After pressing in the clutch, noise disappears but when I start driving from 1st to 5th gear, the noise is back. Even while I'm rollin in neutral or with teh clutch depressed the noise is still there.Could the mainshaft bearings be shot?
Old Mar 12, 2002 | 07:53 PM
Zeus Zore's Avatar
Default Re: strange noise from tranny..... (Mista B-one-seven)
could sound like your cluths is broken ( loss springs) !?! had the same problem..
Old Mar 12, 2002 | 10:18 PM
E-lude78's Avatar
Default Re: strange noise from tranny..... (Zeus Zore)
the clutch, throw out bearing and flywheel are all new
Old Mar 13, 2002 | 10:34 AM
Quik Chris's Avatar
My GS-R tranny has a bad imput shaft bering, the sound goes away when I press the clutch in.
Old Mar 13, 2002 | 11:03 AM
Kamin's Avatar
Default Re: strange noise from tranny..... (Midori Shinkansen)
if it does it in neutral
it aint the transmission.
ho long has it been doing this? sounds like a bad disc or worse...
Old Mar 13, 2002 | 12:56 PM
sgT's Avatar
sgT
Default Re: strange noise from tranny..... (KAMiN)
the main shaft is still spinning when in neutral.
Old Mar 13, 2002 | 01:31 PM
smokin rubber's Avatar
Default Re: strange noise from tranny..... (sgT)
My car makes this noise too. I just put in a new cm stage one clutch and light weight flywheel, the flywheel had a bearing in the center that the stock one did not. I think this is an alignment bearing, Where is the imput shaft bearing?
Old Mar 13, 2002 | 02:22 PM
Kamin's Avatar
but with the clutch engaged would it still spin? (shed some light)
Old Mar 13, 2002 | 05:29 PM
BreakStuff's Avatar
New User
Sounds like a thow out bearing to me.. well,the first part of the post at least..
These bearings will make noise when the clutch pedal is released... if your clutch has manual linkage then you can SOMETIMES remedy the noise by pulling back on the shift linkage boot and spray lubricant in the trans housing hoping it will get to the bearing..
eg_b18c
Transmission & Drivetrain
17
Oct 31, 2018 07:24 PM
RG400SmartTowel
Oct 22, 2009 06:18 PM
SJR
Apr 21, 2005 06:56 PM
Ayeso
Oct 3, 2004 06:22 PM
garados
Feb 3, 2003 11:08 AM
