Boring Out B16A Throttle Body
Old Mar 12, 2002 | 08:34 AM
kungfuSiR's Avatar
Default Boring Out B16A Throttle Body
What' the most you can bore out a B16A throttle body? I was told 63mm anyone here different?
Old Mar 12, 2002 | 08:38 AM
sgT's Avatar
sgT
Default Re: Boring Out B16A Throttle Body (kungfuSiR)
64-66mm is the limit
Old Mar 12, 2002 | 03:40 PM
92gs-r's Avatar
how is it done?
Old Mar 12, 2002 | 09:24 PM
GSRoadRage's Avatar
Default Re: Boring Out B16A Throttle Body (92gs-r)
My god I hope this question doens't mean you are going to attempt to do it yourself!? Have a profesional machine shop do it if you are going to have it done, or just buy a bored out TB. The machine shop down the street from my work bores em out for mustanges, they have a cutting tool like a little arm on the end of a rod that they center in the intake opening and mill the TB out to the desired size. Then they machine a new TB plate out of titanium to replace the old one.
Old Nov 13, 2003 | 11:39 AM
Bizarre's Avatar
Default Re: Boring Out B16A Throttle Body (GSRoadRage)
You say they make a new throttle plate for it which I understand. Do they need to also make a new throttle shaft to hold the new plate? Or do they use the original one?
Modified by Bizarre at 8:09 PM 11/13/2003
Old Nov 13, 2003 | 03:35 PM
EG-lowrider's Avatar
Or if you can find one, Ive heard the GSR TB is like 66 or 68mm, and is a direct bolt on I believe.
Old Nov 14, 2003 | 03:34 AM
Xsi's Avatar
Xsi
No, the GSR tb is 60mm just like the B16a2. The maximum is 64-65mm overbore
Old Nov 14, 2003 | 09:45 PM
831HondaAllmotor's Avatar
talkin about throttle bodies.,my friend can port throttle bodies and the intake manifold.
does it great.
$200
Old Nov 17, 2003 | 12:09 PM
HONDABROMANDUDE's Avatar
Default Re: (831HondaAllmotor)
Sorry for the o-t question but does anyone know the name of the guy here on H-t that does throttle body boring? I did a ton of searches but still couldnt find him.
Old Nov 17, 2003 | 12:31 PM
wickedEFguy's Avatar
Default Re: (itec311)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itec311 &raquo;</TD></TR><TR><TD CLASS="quote">Sorry for the o-t question but does anyone know the name of the guy here on H-t that does throttle body boring? I did a ton of searches but still couldnt find him.</TD></TR></TABLE>
just take it to a local machine shop, probably cost you around $50 at the most
Zaakro
Dec 25, 2006 09:44 AM
4gencivicef9
Jun 15, 2006 02:48 PM
SLO-REX
Feb 20, 2005 12:53 PM
DarkSol97
Sep 11, 2003 11:35 PM
mellowboy
May 11, 2003 05:43 AM
