Strange loss of power when engine warms up
Old Apr 9, 2003 | 07:37 AM
sieger's Avatar
Default Strange loss of power when engine warms up
When I crank my car up cold it runs fine. After letting it warm up if I park it, let it sit a few minutes and then start it up again it will act like it wants to die every so often for 30 seconds. For instance I start it out in first gear then the power drops out, I give it some gas and it surges, shift gears go for a sec, power drops, repeat. Then after about 30 seconds or so it calms down and no prob. Strange.
Chris Fair
Jacksonville, FL
'97 Civic B18C1
Old Apr 9, 2003 | 10:46 AM
sieger's Avatar
Default Re: Strange loss of power when engine warms up (sieger)
Old Apr 9, 2003 | 10:52 AM
B-Tuning.com's Avatar
Check plugs, wires, cap, rotor, timing.
Could be heat soak in the wires, bad rotor/cap, bad ICM/Coil, bad ground, faulty injector(s), dirty air filter... the list goes on and on sadly.
So many things it could be - get yourself a Helms and follow the troubleshooting and testing for the problem.
Try resetting your ECU and see if it repeats the problem afterwards... sometimes I have ignition issues, and a reset clears them up for a few days.
Old Apr 9, 2003 | 09:46 PM
sieger's Avatar
Default Re: Strange loss of power when engine warms up (B-Tuning.com)
Thanks, but I dropped the motor in myself (that's a GOOD thing) and I'm on top of the basics. Looking for similar experiences or insight.
Chris
Jax,FL
'97 Civic B18C1
Old Apr 10, 2003 | 04:18 AM
sieger's Avatar
One more go round. Thanks for playing.
Old Apr 10, 2003 | 04:34 AM
keebler65's Avatar
i had similar symptoms with my b16a, however i wouldnt call it a loss of power. i would say its a rough idle. i fixed it by turning the idle adjeustment screw to make it idle a tad higher, and have had no problems since. the funny thing is i put up with it for a year because i was too lazy to look into it/never remembered to.
good luck.
austinkli
Jan 8, 2014 08:27 AM
hispanic panic
Oct 19, 2011 10:47 PM
dwaynevkao
Sep 6, 2006 07:28 PM
lemongreenhatch
11
Jun 9, 2006 09:30 AM
village_idiot
Oct 9, 2005 05:32 PM
