when turning a crank how hard should it be
Old Apr 9, 2003 | 09:41 PM
eddiecut's Avatar
Default when turning a crank how hard should it be
with the mains on, torqued to specs. i put 1-2-3 on torqued them down, 1-2 were easy stayed at 5lbs of preasure when turning the crank went to 3 and it went all the way to 12-13 lbs. was wondering is that strange?
any replies will be helpful
thanks
Old Apr 9, 2003 | 10:08 PM
iH8RICERZ's Avatar
Default Re: when turning a crank how hard should it be (eddiecut)
lol, HUH?! i have no clue..but good luck tho for us troubled people
Old Apr 9, 2003 | 10:11 PM
Evs-One's Avatar
Solbros Owns Me
Default Re: when turning a crank how hard should it be (iH8RICERZ)
double post
Old Apr 9, 2003 | 10:12 PM
Evs-One's Avatar
Solbros Owns Me
here's what he did...lol
He tightened one main cap at a time and turned the crank inside of that..and it seemed harder to turn with ONLY the 3rd main cap torqued, compared to just the 1st or 2nd main cap torqued....he tried explaining to me, and I said lube em up and torque em all down,....then rotate
Old Apr 9, 2003 | 11:30 PM
eddiecut's Avatar
Default Re: when turning a crank how hard should it be (Emerika)
ok torqued em all down, got em done and lubed up. now i go to turn the crank and its harder then **** to start to turn it and then once it is started its easy as pie wtf??????? is it suppose to be that way?
Old Apr 10, 2003 | 12:20 AM
Kamin's Avatar
you are compressing air, its not supposed to be easy.
Old Apr 10, 2003 | 06:20 AM
eddiecut's Avatar
Default Re: when turning a crank how hard should it be (Kamin)
but it doesnt have pistons on the crank yet, its just the crank, it should be way easy to just turn the crank riiiiight?
Old Apr 10, 2003 | 06:35 AM
CHEETAH's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eddiecut &raquo;</TD></TR><TR><TD CLASS="quote">with the mains on, torqued to specs. i put 1-2-3 on torqued them down, 1-2 were easy stayed at 5lbs of preasure when turning the crank went to 3 and it went all the way to 12-13 lbs. was wondering is that strange?
thanks</TD></TR></TABLE>
what do you mean 1-2-3 torqued them down ? you talking about he journals that you torqued ? I hope not, you need to torque all 5 in a specific criss-cross order or you'll warp the crank ... what about bearing clearances ? have you checked them with plastigage ?
greg
Old Apr 10, 2003 | 08:53 AM
dfoxengr's Avatar
Default Re: when turning a crank how hard should it be (CHEETAH)
inside to outside crisscross.
Old Apr 10, 2003 | 09:17 AM
psi420's Avatar
Default Re: when turning a crank how hard should it be (hybridvteceg)
Did you use new bearings and new assembly lube?
Dont rotate the crank while torquing the caps.
How did you store the crank while it was out of the car?
You should stand it on end, or place it back on the block if the block is out.
Cranks can, and do warp!
Modified by psi420 at 11:21 AM 4/10/2003
Old Apr 10, 2003 | 06:23 PM
eddiecut's Avatar
Default Re: when turning a crank how hard should it be (psi420)
cranks not warped had the machine shop take a look at it today. maybe the cap is bent??????? thas one of the only things i can come up with right now
Old Apr 10, 2003 | 08:03 PM
eddiecut's Avatar
redline assebly lube. new bearings acl.
Old Apr 10, 2003 | 11:03 PM
psi420's Avatar
You sure you have the right assembly order on those caps?
Just checkin, you never know.
b20beast83
30
Oct 19, 2009 12:45 PM
krhagon
Mar 29, 2008 05:17 PM
chu77
Sep 4, 2006 02:03 PM
eddiecut
Mar 26, 2003 05:48 AM
T-sohctec
Feb 19, 2003 06:17 AM
