skunk2 cams???????????????
Old Apr 10, 2003 | 04:20 PM
dabomb's Avatar
Default skunk2 cams???????????????
how can you tell the difference between the stage1's and stage2's or even the stage 3's???
i tried the search but its not working
Old Apr 10, 2003 | 07:01 PM
Civichatch2k's Avatar
Default Re: skunk2 cams??????????????? (dabomb)
Well the lobes should be quite a bit bigger whenever you are looking at the different stages.
If you are buying them from someone then you might call skunk 2 and find out the specs on the stage you think that you are buying and them measure the cam to see if the lobes match up to the specs.
TimeRacer
Oct 9, 2004 03:16 PM
10K2HVN
Jul 4, 2003 02:28 AM
pIMp NO
Mar 26, 2003 06:36 PM
Rembrant Q. Einstein
May 20, 2002 11:47 PM
