Violent Shaking Under Acceleration
Old Nov 16, 2003 | 05:03 PM
preludebb4's Avatar
Default Violent Shaking Under Acceleration
I have a 93 Prelude Si, I swapped the motors with a JDM H22A this summer and I love it, well about a month ago my car started shaking under acceleration and so I figured it was an axle, so I replaced the passenger side axle and the problem was solved. Then about a week later the problem came back again, so I replaced the passenger side again and it didnt fix anything. So I just finished changing both axles for brand new axles, not reman, they are GCK from advanced auto parts, I know they arent the quality of RAXLE or anything, but I dont have the money for those right now. A few friends of mine thought that it was motor mounts so they told me to pull up the e-brake and try to drive forward and back to see if the motor moved a lot either way, and it doesnt hardly move at all. I dont want to have to take it to a repair shop becuase they like to rape people. So any suggestions would be appreciated.
Old Nov 16, 2003 | 06:39 PM
omega11855's Avatar
i think its your mounts just look at the rubber is it broken?
Old Nov 16, 2003 | 08:21 PM
Good ol' Screwtape's Avatar
Multi-paradigm
Default Re: (omega11855)
clutch, pressure plate, flywheel
Old Nov 25, 2003 | 01:16 PM
Mach30SiR's Avatar
Default Re: (haku-jitodai)
https://honda-tech.com/zerothread?id=299682
according to that, its the inner CV, but how can i tell if its causing the shaking, i just had my axles done today, and i shake alot, and they are trying to pawn it off on the engine mount.
Old Nov 25, 2003 | 01:44 PM
thegrinch's Avatar
Default Re: Violent Shaking Under Acceleration (preludebb4)
bad axles. not in balance
Old Nov 25, 2003 | 02:28 PM
Mach30SiR's Avatar
Default Re: Violent Shaking Under Acceleration (thegrinch)
thanks, they tried to tell me it was my engine mount, i'm pissssssed off i'm gonna go break heads tomorrow
Old Nov 25, 2003 | 04:00 PM
lazy bum shaughn's Avatar
Maybe it's your balance shafts, doubt it though.
Old Nov 26, 2003 | 09:18 AM
preludebb4's Avatar
I found out what the problem was, my car was too low. The eibach sportlines dropped my prelude like 3 inches which was really low so it caused the axles to bind and wear out in like 2 weeks. I raised the car back up on stock springs, replaced the axles again and the problem was fixed, I guess I will have to go with a full coilover setup next time.
Old Nov 26, 2003 | 02:07 PM
Jimmy's Avatar
Global Moderator
Default Re: (preludebb4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by preludebb4 &raquo;</TD></TR><TR><TD CLASS="quote">I found out what the problem was, my car was too low. The eibach sportlines dropped my prelude like 3 inches which was really low so it caused the axles to bind and wear out in like 2 weeks. I raised the car back up on stock springs, replaced the axles again and the problem was fixed, I guess I will have to go with a full coilover setup next time. </TD></TR></TABLE>
Aturbo88
Jul 27, 2009 09:59 AM
BoltonGSR
Apr 3, 2009 06:15 AM
turbob16ef
Nov 12, 2005 01:13 PM
vteccivhatch
Sep 20, 2005 07:59 PM
LookingForVTEC
Nov 21, 2002 07:39 PM
