Next NSX (HSC) to be SOHC?
Old Nov 12, 2003 | 08:42 PM
powerofdreams8's Avatar
Default Next NSX (HSC) to be SOHC?
Maybe I am horribly confused but does this picture not indicate that the HSC will be of a SOHC configuration?
Old Nov 12, 2003 | 08:44 PM
CleenSi
Guest
Posts: n/a
Default Re: Next NSX (HSC) to be SOHC? (powerofdreams8)
no thers 2 cams there.
Old Nov 12, 2003 | 09:01 PM
Default Re: Next NSX (CleenSi)
CleenSi: Don't ever talk. Again. Ever.
Old Nov 12, 2003 | 09:14 PM
1994AccordSiR's Avatar
end yourself, now
Old Nov 12, 2003 | 09:37 PM
michael O's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CleenSi &raquo;</TD></TR><TR><TD CLASS="quote">no thers 2 cams there.</TD></TR></TABLE>
A v6 has two heads...the picture shows one cam on each head...thus making it a single overhead cam configuration.
Old Nov 12, 2003 | 10:09 PM
Se-rv-Tak's Avatar
Default Re: Next NSX (michaelOlson)
SOHC-SingleOverHeadCam
DOHC-DualOverHeadCam......
look at each of the head's? and look closey....
Old Nov 12, 2003 | 10:58 PM
TeStUdO's Avatar
If they were DOHC, wouldnt you call it a Quad Cammer???? Just wondering...........
Old Nov 12, 2003 | 11:25 PM
slowazzhatch's Avatar
Default Re: Next NSX (Soon2B18Boost)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Soon2B18Boost &raquo;</TD></TR><TR><TD CLASS="quote">
look at each of the head's? and look closey....</TD></TR></TABLE>
we are aware of this, but why make it a SOHC, honda has always made the most power with DOHC, not SOHC, the point we are trying to make is why are they going SOHC - it there something we are missing?
only thing i can see if that the single cam with roller rockers make it to where the valve can move farther up and down - therefore letting more air in and more exhaust out...this is the only reason i see why honda would do this
intelligence is what we are looking for, we can see there is 2 cams and not 4
Old Nov 12, 2003 | 11:59 PM
aznxphreak's Avatar
Yeah, I see a SOHC too. What's so confusing? I guess the "V" 6 is confusing people that are more used to inlines. And yes a DOHC V6 does have 4 cams. Anyone have a picture like that (like crosssection) of a W8? Now that would have a 4 cam configuration on SOHC and 8 for DOHC. =D
Oh yeah, slowazz. If the SOHC were only beneficial in creating a higher lift in the valves, why couldn't they make higher profile lobes in the camshafts?
Old Nov 13, 2003 | 05:41 AM
Daemione's Avatar
Default Re: Next NSX (aznxphreak)
It's more than likely going to be a J-series V6 . . . and they're all SOHC. But it's not like it's hard to make power with those engines, so it doesn't matter to me. The new TL's already put down almost as much power as the current NSX. A more aggressive cam profile, better exhaust manifold, & a massaged head . . . . 300 whp easy.
And the only real advantage DOHC holds over SOHC is the ability to tune via cam gears after the fact. Plus SOHC often offers the advantage of less reciprocating valvetrain weight, and straighter intake/exhaust paths in the head.
Old Nov 13, 2003 | 06:25 AM
91integraLSVTEC's Avatar
then y does the dohc make more power.. look at the d-series engine
Old Nov 13, 2003 | 07:33 AM
Rtype16's Avatar
Default Re: (91integraLSVTEC)
hahaha cleensi... This just goes to show you I will never change my sig... Read it and enjoy explains alot of postings on the internet.
A SOHC can make more power becasue of less reciprocating mass, but there is always a but, most SOHC motors are designed to be usually smaller less efficient motors than that of a DOHC. Also the grinds on the cams on a SOHC would have to be perfect as to where on a DOHC cam the intake cam and exhaust cam are seperate and the timing of the cams can be changed independently instead of like that of a SOHC.
Daemione's Avatar
Correlation does not imply causation.
DOHC is often used on high-revving 4-cylinders, 8-cylinders, & inline 6-cylinders because the cams are so long -- too many lobes on a single shaft can reduce reliability at high rpms.
Old Nov 13, 2003 | 07:46 AM
ChronicWorks's Avatar
not all 2 cam v6's are sohc design... prime example is the vw vr6.... 2 cam dohc v6
Old Nov 13, 2003 | 07:56 AM
Daemione's Avatar
Default Re: (ChronicWorks)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ChronicWorks &raquo;</TD></TR><TR><TD CLASS="quote">not all 2 cam v6's are sohc design... prime example is the vw vr6.... 2 cam dohc v6</TD></TR></TABLE>
Prime example is a good word, since it's the only example. Of course, it's arguable that the VR6 doesn't even count as a V6 . . . . only one head and the cylinders aren't parallel.
It's also worth noting that some 4-cam V engines still function as SOHC . . . . One cam drives the other on each head, so it's impossible to adjust intake or exhaust independently unless you get a different grind in there.
Old Nov 13, 2003 | 08:44 AM
JimBlake's Avatar
Default Re: (Daemione)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Daemione &raquo;</TD></TR><TR><TD CLASS="quote">... the VR6 doesn't even count as a V6 . . . . only one head and the cylinders aren't parallel...</TD></TR></TABLE>Yes. Even VW has occasionally described it as an inline-6 with staggered bores.
And... Sometimes SOHC is used because of space. Look at that engine up at the top of the thread. Maybe(?) a DOHC head would take up too much space, requiring a more restrictive intake manifold.
Old Nov 13, 2003 | 09:10 AM
iwhichisme's Avatar
I thought they were always sohc
Old Nov 13, 2003 | 09:47 AM
CleenSi
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by michaelOlson &raquo;</TD></TR><TR><TD CLASS="quote">
A v6 has two heads...the picture shows one cam on each head...thus making it a single overhead cam configuration.</TD></TR></TABLE>
yea makes sense...didnt know that
sorry for the misconception
Old Nov 13, 2003 | 09:48 AM
raene's Avatar
I believe SOHCs also have longer rocker arms, causing higher valvetrain instability at high rpms. That's why the DOHCs rev more - the rockers are nowhere near as long as on a SOHC.
Old Nov 13, 2003 | 09:50 AM
CleenSi
Guest
Posts: n/a
Default Re: (TeStUdO)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TeStUdO &raquo;</TD></TR><TR><TD CLASS="quote">If they were DOHC, wouldnt you call it a Quad Cammer???? Just wondering...........</TD></TR></TABLE>
that was also sorta the thought going thru my head.
Old Nov 13, 2003 | 02:29 PM
Rtype16's Avatar
Default Re: (raene)
Not really yes they are longer, but if built right you will not have a problem. The biggest problem would be the actual valvetrain being able to sustain a high RPM. I built a car SOHC which we could rev to 12500 all day long D16.
Old Nov 13, 2003 | 02:51 PM
aznxphreak's Avatar
Default Re: (raene)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by raene &raquo;</TD></TR><TR><TD CLASS="quote">I believe SOHCs also have longer rocker arms, causing higher valvetrain instability at high rpms. That's why the DOHCs rev more - the rockers are nowhere near as long as on a SOHC. </TD></TR></TABLE>
I see rollers instead...
Old Nov 13, 2003 | 05:07 PM
MrTodd's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by powerofdreams8 &raquo;</TD></TR><TR><TD CLASS="quote"> </TD></TR></TABLE>
I'm still trying to figure out were the sparkplugs are supposed to go... The cam is in the way..?
Old Nov 13, 2003 | 06:49 PM
.dave's Avatar
i HAS questions ?
Default Re: Next NSX (MrTodd)
Look just to the inside of the valvesprings for the exhaust side. There are long cylindrical tubes going from the valvecover down. I'm assuming thats what they are, as thats what they looked like on my D16.
Old Nov 13, 2003 | 07:03 PM
boondockgtr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MrTodd &raquo;</TD></TR><TR><TD CLASS="quote">
I'm still trying to figure out were the sparkplugs are supposed to go... The cam is in the way..?</TD></TR></TABLE>
hmmm that made me think of something.... i read in a mag recently that honda had just built its first Diesel engine. Now bear in mind that i don't know what a diesel engine looks like internally, but i do know that they don't have spark plugs. Could this be the honda diesel engine?
