Just finished swap and having troubles....
Old Nov 12, 2003 | 09:57 AM
GSR-T-'s Avatar
Default Just finished swap and having troubles....
I just finished putting a turbo type R motor in my car. The whole setup came out of 92-95 civic. I have a 2000 gsr. When I did the swap I used my wiring harness out of the gsr along with my distributor. A bunch of plugs did not plug up however I was informed that this would be ok. It has 1000cc injectors and hondata. The motor ran perfect before I swapped it over but now it starts up and just shuts off. I adjusted the throttle to where it will idle fine but the car runs really bad. Do you guys have any suggestions?
Joe
Old Nov 12, 2003 | 10:35 AM
GSR-T-'s Avatar
up
Old Nov 12, 2003 | 10:51 AM
mmuller's Avatar
Mad Scientist
Default Re: (GSR-T-)
you have obd2-obd1 harness?what kind of plugs didn't work?any cel's?
Old Nov 12, 2003 | 12:45 PM
GSR-T-'s Avatar
Default Re: (mmuller)
I have an obd2 harness on the motor and the obd2-1 harness on my p28 hondata ecu
Old Nov 12, 2003 | 12:46 PM
GSR-T-'s Avatar
as for plugs I just matched em up off my gsr motor to the location they came from
sacicons
Oct 23, 2009 09:46 PM
Stillmatic22
Aug 16, 2004 01:41 PM
Seye
Aug 7, 2004 01:19 PM
EG6-madness
Mar 21, 2004 08:09 PM
GSR-T-
Nov 12, 2003 06:48 PM
