Jerky, stagnate acceleration...
Old Nov 15, 2003 | 04:27 PM
GapxGuy's Avatar
Sushi Buffet Champion
Default Jerky, stagnate acceleration...
I have a B20vtec, when I accelerate almost half the time it jerks or is stagnate (barely pulls). Also jerks when shifting, it's hard to do a smooth shift.
Funds were low after the swap, so it's still running on old/used B20 spark wires and plugs. The distributor is from a 99 Si and rotor hasn't been changed. Still
running on the B20 injectors.
ECU is P73, fuel pump is 99 Si. Running on a stock exhaust system.
Please help. TIA.
Old Nov 15, 2003 | 04:40 PM
ljoe's Avatar
Default Re: Jerky, stagnate acceleration... (GapxGuy)
has it ever thrown a cel? if so, check that, and either way, try replacing the fuel filter, they're like $10, so even if that ends up not being the problem, you didn't really waste any money
Old Nov 15, 2003 | 04:44 PM
GapxGuy's Avatar
Default Re: Jerky, stagnate acceleration... (ljoe)
No, it doesn't throw a cel. I was hoping it'll be fuel delivery or spark management. But some said the B20 block and the vtec head throws off the oil pump sensor causing the jerkiness and I would need to switch to the P28 ecu. Any thoughts?
Old Nov 15, 2003 | 05:29 PM
dunkd's Avatar
so by jerking do you mean it's missing? sounds like a spark problem to me.
Old Nov 15, 2003 | 05:34 PM
GapxGuy's Avatar
Default Re: (dunkd)
What do you mean it's missing, what's missing?
https://honda-tech.com/zerothread?id=678954
Old Nov 15, 2003 | 05:41 PM
dunkd's Avatar
like one cylinder isn't firing once in awhile, so it jerks.
do a tune-up. plugs, wires, rotor.
jerrys7583
Mar 23, 2011 12:59 AM
92slamed4door
11
Feb 28, 2011 09:24 PM
GapxGuy
Nov 15, 2003 05:26 PM
GapxGuy
Nov 15, 2003 05:07 PM
