check engine light on after clutch intall
Old Nov 13, 2003 | 06:49 AM
6thgenaccord1's Avatar
Default check engine light on after clutch intall
Last night i installed act clutch in my boosted 98 accord and the check engine light came on, the car is also idling strangley high, does anyone have any clues on why this is happening?
Old Nov 13, 2003 | 08:35 AM
JimBlake's Avatar
Default Re: check engine light on after clutch intall (6thgenaccord1)
The ECU doesn't know or care about what's going on at the clutch. So look for wires pulled apart, or maybe a sensor the got broken when you were dropping the tranny. What did you unplug to make room to work? Did you forget to plug something back in?
Old Nov 13, 2003 | 09:45 AM
doublejz's Avatar
Default Re: check engine light on after clutch intall (JimBlake)
find out what code its throwing, that would make it alot easier
Old Nov 13, 2003 | 10:19 AM
chadmasterc's Avatar
Default Re: check engine light on after clutch intall (doublejz)
make sure there arent any wires pinched in between the tranny and engine. This happened once while i was helping a friend install a tranny.
passwordhatch
Jul 9, 2006 11:26 PM
DaMmniTz
Feb 20, 2005 12:55 PM
6thgenaccord1
Nov 13, 2003 09:23 AM
blacksi00
Apr 29, 2003 10:03 PM
