Map Sensor Acting up in the rain?
Old Nov 13, 2003 | 09:57 AM
kikicamacho's Avatar
Default Map Sensor Acting up in the rain?
I drive a 94 civic with the stock D15B7 and yesterday it rained alot here in Phoenix. Well after work my car wouldn't start. I was practically on E so I poured a couple galons of fuel into the tank, but it still wouldn't start. so then I pulled a spark plug wire to check for spark. It was weak but still sparked nonetheless. So I figured fuel might not be getting to the engine, I tried cranking while spraying some starting fluid, still no go. When I was reattaching the intake tube to the tb I disconnected the Map sensor and reconnected it. after that it started but sputtered really bad. so we jiggled the map sensor and finally it fired right up. So my question is: Can a map sensor be so adversely affected by humidity/moisture that it prevents a car from starting? I don't have a CAI, just a short ram. Is my Map going bad or are all map sensors this finicky when it comes to wet weather?
Old Nov 13, 2003 | 10:55 AM
bruthaboost's Avatar
Default Re: Map Sensor Acting up in the rain? (kikicamacho)
Your problems sound more like a distributor cap sealing issue. I'd swap out caps and make sure you have a good seal on it. When any kind of moisture gets in there you'll get the symptoms you're describing.
Old Nov 13, 2003 | 01:24 PM
Default Re: Map Sensor Acting up in the rain? (bruthaboost)
Now that you mention it. I did look inside the distributor and isn't there supposed to be a rubber gasket it sits on? Mine didn't have it, and when I held the cap in place while someone cranked the car over I got Shocked! I half expected that. But yeah I think my problem is the distributor cap gasket missing.
Old Nov 13, 2003 | 01:57 PM
Yeah, you need that rubber gasket seal. Good luck with this.
JayDMJ
Engine Management and Tuning
Sep 9, 2017 12:24 PM
Randyb18
Aug 9, 2015 03:07 PM
MatthewMenze
May 1, 2014 01:24 PM
zccr-xsi
Dec 2, 2006 06:22 AM
alfee
Aug 16, 2006 01:07 PM
