how to test MSD products?
Old Mar 22, 2004 | 10:11 AM
Charlie Moua's Avatar
Default how to test MSD products?
is there a way to see if my blaster coil is still good?
I have msd 6al and blaster2 coil....
I was having some problems with my distributor and so i replaced the OEM IGNITOR and now the car doesn't start....
I'm thinking it may be my msd box or my coil blaster, but not totally sure.
Old Mar 22, 2004 | 10:43 AM
Default Re: how to test MSD products? (Charlie Moua)
bump
Old Mar 22, 2004 | 11:05 AM
timmy8151's Avatar
For the stock ignition coil, I checked the resistance across the Primary and Secondary connections. I'm not sure if the MSD has the same resistance specs though.
Old Mar 22, 2004 | 11:56 AM
Default Re: how to test MSD products? (timmy8151)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by timmy8151 &raquo;</TD></TR><TR><TD CLASS="quote"> For the stock ignition coil, I checked the resistance across the Primary and Secondary connections. I'm not sure if the MSD has the same resistance specs though.</TD></TR></TABLE>
thank you!
now can you kinda explain what primary and 2ndary connections are???
are you referring to the termainal (power and ground)
Old Mar 23, 2004 | 05:13 AM
ANYone else?
ATS*Mark
Jan 31, 2005 08:11 PM
K-Spec
Jan 8, 2005 03:48 PM
mrod006
Aug 1, 2004 09:48 PM
integrasi
Mar 5, 2003 12:28 AM
