built motor and AFC question...
Old Mar 25, 2004 | 11:16 AM
builthatch's Avatar
MiG-21 superfan
Default built motor and AFC question...
on the apexi site, it says that 12-14%+ will sometimes induce a check engine lite, due to the map sensor voltage being so low (as if it sees boost, the afc manipulates the map sensor signal and fools it inot thinking more air is going thru than what is really going thru, so in turn, more fueling occurs)...well, my car, sometimes, will throw a lite it seems from it being set at 11%+.... I think it mite be from that fact that my car sees a little bit of positve manifold pressure at full throttle; the afc will show .01-.02..where as most NA hondas it seems at full throttle show .00..my theory is, my high compression, big cam, porting, etc make the map sensor voltage that much lower at full throttle than most hondas due to the increased air being pulled in, so the lite being thrown @ 11% makes sense.
Do you agree?
Old Mar 26, 2004 | 08:44 PM
builthatch's Avatar
MiG-21 superfan
Default Re: built motor and AFC question... (builthatch)
Old Mar 26, 2004 | 09:07 PM
ben95ex's Avatar
yeah, it makes sense to me.
on a stock engine even at WOT there will still be a little vacuum in the manifold... modifying it for higher airflow would get you closer to zero vacuum in the manifold at WOT, therefore the same amount of correction with an AFC would put what the ECU sees at a little higher than with a totally stock engine.
Old Mar 26, 2004 | 09:25 PM
builthatch's Avatar
MiG-21 superfan
Default Re: built motor and AFC question... (ben95ex)
Thanks!
Turns out it does it @ 10%, but not 9%...strange how it jsut started to be so sensitive to this, who knows.
JDMEMone
Engine Management and Tuning
Dec 10, 2014 06:26 AM
backwoodsman
Mar 26, 2007 07:03 AM
builthatch
Mar 26, 2004 11:12 AM
Kataku2K3
Oct 21, 2002 02:11 PM
thashadow
Jun 12, 2002 11:35 AM
